Leading on from my other post where i showed some nice pics of my E30 after her first polish of the year I thought I would make a post showing all the nasty scabby bits on the motor.
I urge others to follow suit.
IMO I have no major problems, all the bits shown below are relativity easy fixes my two biggest areas of concern are the slight rust on the scuttle and a rusty dent on the rear boot panel.
Slight rust on drivers side door
Nice bit of rot on the front valance D/S
These seems near the sills seem to be rusting slighty, had a good poke and they are still very solid
Dent on the rear boot panel, that’s starting to show signs of rust.
Both of the rear pop outs have started to rub the paint of where the close, not rusty as yet but need to address asap
Both sides of the scuttle are showing early signs of rust, should have caught it early enough to avoid having to cut and weld new metal in.
Bubbling on mirror base
School boy error of mine, buring the paint while using a machine polisher
Need to sort the headlights out as they mountings are shagged and give very poor visibility at night time.
Headlight switch needs fixing as its hanging out
Heater panel needs re fitting, as its sticking out slighty
Fuel gauge not working properly
Need some OE tweeter pods as these just look a mess
LHD heater panel needed so my screen can come out without hitting the indicator stalk.
Glove box needs attention as its a right pain to close, think the latch needs adjusting
Need two new mirror glasses as the current ones are shagged
Drop links need replacing, making a clunking noise at the moment.
Need to fix the hangers on my exhaust, tbh not keen on the sound of this powerflow system so may just fit an OE system.Big list of jobs there, a full respray should all the body work issues and then there just loads of little jobs and fixes to do. Seems like a big list but should be fairly easy and inexpensive to fix especially as i have a mate who works in the paint business and will spray the whole car for me as long as I pay the £300 to run the booth/oven and buy the paint.
Heres a link to some nice pics of my E30...
