check the usual rust areas, battery tray, rear arches, scuttle, jacking point areas, rear valance around tow hook, etc.
the water in the boot is no big deal, usually only rear light seals or bootlid seal.
the water sitting in the jack area is common, hence the bootlid condensation.. just clear the drain hole at the bottom on the "well" and let the water run out.
the rusty tools will scrub up...or buy an as-new set from me
pictures would be a good idea.
what area are you in?
BTW: this is the Photo Gallery.
you should try this section:
http://www.e30zone.net/modules.php?name ... wforum&f=2
HTH
[quote="bss325i"]
