I saw this on Retro Rides and thought it might be a good idea to put up a 'contents' thread so people can find picture/build threads for particular cars.
How it works:
Post a brief description of your car. E.g:
"1989 325i touring, Megasquirted on LPG"
This will form a link to your build thread. This is achieved by adding URL tags before and after the description. I have broken this down below (without the last square bracket):
[url=http://www.e30zone.net/modules.php?name ... c&t=126336&]1989 325i touring, Megasquirted on LPG[/url
Then underneath, post a SINGLE image of the car as you would in any other thread. There is a good tutorial on how to do this stickied in the photo gallery section.
I will follow this post up with an example to get the ball rolling.
The easiest way to get the link right is to 'quote' my first post, remove the [quote] tags then edit the link URL and image as per the explanation above.
Please attempt to follow the format laid out here so the thread becomes easy to read. Also if the mods deem this a good idea, a sticky and some housekeeping help would be greatly appreciated... If this thread can be kept tidy, it would make a good point of reference.
In all politeness, NOTHING ELSE SHOULD BE POSTED IN THIS THREAD
The E30zone Register
Ilkorin
Ilkorin
