Post
Sun Oct 24, 2010 2:16 pm
I got the Factory Spec for my car from the Dealers when I was there the other day..............
Type code AF92
Type 318IS (EUR)
Dev. series E30 ()
Body type LIM
Steering RL
Door count 2
Engine M42
Cubical capacity 1.80
Power 103
Transmision HECK
Gearbox MECH
Colour ALPINWEISS 2 (218)
Upholstery UEBERKARO II ANTHRAZIT (0379)
Prod. date 1991-01-17
199 EQUIPMENT FOR LEADED FUEL
210 ANTI-BLOCKIER-SYSTEM ( ABS )
215 POWER STEERING,DEPENDING ON ENGINE SPEED
281 LM-RAD 6 1/2 X 14
314 HEATED WINDSCREEN WASHER NOZZLES
350 WAERMESCHUTZGLAS GRUEN, RUNDUM
401 SLIDING/VENT ROOF, ELECTRIC
410 WINDOW LIFTS, ELECTRIC AT FRONT
428 WARNING TRIANGLE
481 SPORT SEATS F DRIVER/FRONT PASSENGER
520 FOGLIGHTS
556 EXTERIOR TEMPERATURE DISPLAY
812 ENGLAND VERSION
850 ADD FUEL TANK FILLING FOR EXPORT
925 SHIPPING PROTECTION PACKAGE
I've been busy doing the niggly little things since I got her. Problems i've found were:
Slight Over Heating, fixed with New Thermostat & Viscous, Renew & Bled the Cooling System.
Erratic Idle, Work In Progress, hoping to get sorted this week. The car has erratic idle when the Breather pipe from the R/C is connected, disconnect it & it idles fine. Going to check the TPS & the ICV this week.
Wipers not working on intermittent, fixed by using the guide in the Wiki, strip, clean & Re-grease the motor.
Alarm inop. Took apart the Siren, & needs new battery. Got one ordered so should be fixed soon.
Rear top mounts need doing.
Erratic Temperature Gauge. Hopefully fixed, not tested yet. I read that it is a bad earth connection, so removed the cluster, & the nut holding the Temp Gauge in was loose. Tightened it so will see if this fixes it.
