I'm new to the E30 scene, just picked up this with 12 month MOT and 6 month tax for £680! A bargain I reckon (even with the complimentery problems). Planing on learning to drift properlly, my friend has got me hooked. He has a clothing company involved in the drift scene, I've ended up getting involved and its going to cost me...
Its a 318is
Standard engine
Lowered
15" BBS Alloys, (two centre caps nicked second day I had it....)
Rather large exhaust
Weird Mirrors.....
The car is quite clean, but has a few issues I hope to iron out;
Replace exhaust for standard
Replace mirrors for standard
Replace cracked and welded sump, make up a sump guard in work for it
Get electric windows to work when the doors are closed (currently only working when windows are open, its blown a fuse in no17 but I'd like to know why)
Sort out earthing problems with the fuel and temp guage (should be a quick fix)
Alarm and immobiliser has been ripped out, no idea why might have been malfunctioning. Need to reinstal that somehow....
Fit a radio and some speakers, they were taken out before I had the car
Sort out dash lighting, bulbs seem to be missing here and there
Try and get the headlight leveler to work again, not sure how they work but I'll soon find out
Find out why the service/inspection light is on red, I've heard mentions of a board needing replacement but I shall look into that last
Get cable handbrake working properlly, seems to roll back 1/4 of a foot on a hill before stopping
Performance/engine wise, the long term plans are
Hydraulic handbrake (vertical)
Chip
Lighten/Change flywheel. Need to shave some weight off that thing!
Change timing chain and sprockets, chain has been changed a few times, can't see any recipts for a sprocket though.
Investigate whining noise coming from rear of the car, think it may be the diff, not sure if theres even any oil in there. Also need to check if theres an LSD down there or not, if not I'll get round to buying one at some point.
Thought has occured to me to turbo charge it, I've got a garret t3 going spare, just needs a service and a new inlet impeller. Think that plan might be more long term though.
Thats all for now, I'll try and keep this up to date, in between sorting out the rest of my aging fleet.....
