Behold.. The Rail of Fuel
DmcL
Post Wed May 05, 2010 7:10 pm
yea, yea i know its not a whole car but it will be going on the car soon-ish. debating whether or not to send the injectors off to be ultrasonically cleaned or not.
FPR and injectors are off of an M30 3.5, think the regulator is the same as on the M20 but since i had a spare M20 rail i figured why pull my old FPR to fit on this rail with the M30 injectors when i can just use the M30 FPR instead so i set about stripping the black coating on the FPR and then sanding and polishing the christ out of it. dunno how long that painless performance sticker will last tho lol
crappy camera phone pics FTW!!
also if any of the converts might be interested i have the M30 fuel rail left over and would part with it for not alot of tokens as its of no use to me.
WMMotorsports
Post Wed May 05, 2010 7:24 pm
Is there any advantage to upgraded FPR, i thought they were a waste of time ?? or do you need injectors to match?
i would get the injectors cleaned while they're out
DmcL
Post Wed May 05, 2010 8:48 pm
i think the M30 and M20 FPR's are both 3 bar. prob same part number and all.. just thought id put the one off the M30 rail in for good measure and keep the other for a spare or to flog on or whatever.
WMMotorsports
e30daniel
Post Wed May 05, 2010 10:12 pm
they are handy if you need to keep the pressure higher for large injectors to keep a fine spray pattern.
that is a yummy setup.
DmcL
Post Thu May 06, 2010 12:32 am
near sure the regulators are the same for M20 and M30. think only the 2.7 found in the e models used a 2.5 bar regulator. my M20 reg is painted so no chance of a part number check, etc and since this M30 one seems fine i figure it cant hurt.
chuffed with how the regulator came up, thumbs were starting to feel crampy at one stage lol
WMMotorsports
DmcL
Post Thu May 06, 2010 12:58 am
i think i have officially lost my mind lol
just repainted the fuel rail in a glossy VHT paint, wsnt liking the matt finish of the spray so i did it in a gloss finish with a sponge to get a little texture to the finish and if that wasnt bad enough i just took a notion and started sanding the body of one of the injectors.. and now that i started ill have to finish.. all 6 of them.. :mad:
should look good once a lick of autosol goes onto them. have 2 of them sanded/polished and another 4 to go. will finish those tomorrow tho :)
be a shame to put this rail on the car after all this lol
WMMotorsports
