anyway..... heres some pics from the advert i bought it from
as you can see from the bay shot , the loom is a bit of a mess..... anything that didnt reach the correct mounting points again .....cable tied...
i have stripped the loom and fitted the correct bulk head plastics and made brackets for the bottom of the inlet manifold to secure the sensor wiring to and the fuel pipes which were also hanging loose.
the car had dark gray rear seats and light gray 318is front recaros.... these have also been replaced with full imaculate touring standard interior.
ive replaced all the lights with smoked stuff, new front brakes, new suspension as it had gmax kit on it which i dont really rate that much to be honest. genuine schnitzer wheels, replaced the heater blower motor, replaced rear abs sensors as the wiring had been cut for som reason, fitted a thermostat as it didnt have one for some reason....running fine with new one!!
slowly making a half decent car from this..... rear subframe bushes and roof lining are next as the bushes have been done but one is only half fitted into the axle and the plates that fix to the sill are upside down and on the wrong sides
heres how its looking today
