328i M20 Sport Resto (Black and Gold)
scott180gtb
Post Sat Jan 09, 2010 9:04 pm
Thought I would start of another restoration thread. This is my sport after my second outing to the Squires meet at Sherburn. Some how I managed to find the only dear in York on the way home. Sadly I only have pictures post dear. As you can see the car was a fairly clean 90 Schwartz black on the outside. She had had some poor paint down both sides and was in need of some replacement panels to the arse area. However when you really start to dig you can find some serious grot!
I have only been involved in the zone since late last summer but have been inspired by some of the restorations and knowledge on hear.
So hear goes with some of my work so far. I have basically pulled the car to bits. My original plan was to completely restore the car myself, learning the skills on the way but I have chickened out and enlisted Beardymatt for the paint and body work. My welding is not much cop! I have sourced some good rust free original panels. Two doors, two front wings, boot lid the rest is going to be OEM stuff from the dealers. The list of panels is long and scary!
I have pulled the complete drive train of the car. The front struts and sub frame are all at the powder coaters along with some other bits. Everything will be new under the car. I have bought new brake lines, fuel lines, clips, screws, bushes so that it’s all brand new when I put it back together. I am going to need lots of advice on the way so please don’t hold back with any comments or suggestions.
Post Sat Jan 09, 2010 9:11 pm
:cool: Looking good, looking forward to the updates
The_Diddler
Love it up the more door !
Post Sat Jan 09, 2010 9:20 pm
Nice to see another E30 been saved :D
Whilst you've got everything off underneath it would be rude not to sort out the little bits of rust here and there on the underside.
Split factory underseal can hide many a waiting rust trap, all those small brown stains in your photo highlight most of the problems from what i can see.
On mine firstly i throughly cleaned underneath, then used wire wheels of varying sizes in a drill to scuff back the factory underseal to good metal to reveal the rust problems, you'd be surprised how far it spreads 8O
Once that was done i treated the rust, applyed zinc/etch primer, then brushable underseal, grey primer and then top coat.
This should keep mine fresh underneath for a good few years, i too have enlisted Beardymat, weather permitting the car will be with him on Monday :D . All new parts underneath for me as well, got to be done.
good luck, i look forward to seeing your progress, mines below:
Warning: you will see images of moredoor rightness, for those viewers of a nervous disposition, please switch channels :D :D
The_Diddler
Post Sat Jan 09, 2010 9:21 pm
Oh forgot to mention the 3 circular discs in the bodywork (2 in the rear passenger footwell, 1 spare wheel well) like to rust badly, give those a poke, and change them if required, i have the part number if you need them....
scott180gtb
Post Sat Jan 09, 2010 9:35 pm
Already pulled the plugs out. Ok they fell out! Need to get the underside sorted. Waiting for some sun to warm the floor up!
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone :(
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
The_Diddler
Post Sat Jan 09, 2010 9:41 pm
Actually i just looked at my plugs sternly, they crumbled to rust instantly 8O 8O :D
Post Sat Jan 09, 2010 9:42 pm
how long does it take to scrape all the old underseal off diddly :)
Post Sat Jan 09, 2010 9:47 pm
Good to see another Sport getting the attention they deserve! :cool:
Keep the pics and updates coming, good resto threads are the best!
The_Diddler
Alex wrote:how long does it take to scrape all the old underseal off diddly :)
Sent PM, so as too not clog this thread up :D
/// KAMI
Post Sat Jan 09, 2010 11:09 pm
looking good pal keep it up the good work
THE ULTIMATE DRIVING MACHINE
scott180gtb
Post Sun Jan 10, 2010 5:00 pm
Paul
What products did you use on the underside? I have some degreaser we use at work. I was thinking of spraying all over then jet washing off. Wire brush the old under seal off in the suspect places. What types/brands of krust, primer, under seal and paint did you use? Just checked out your thread. Look's nice and clean! You can't beat a clean under carriage. winkeye
Cars
The_Diddler
Post Sun Jan 10, 2010 9:48 pm
Used "Meguiars" Super degreaser and "Bilt Hamber" Surfex hd degreaser either neat or diluted 2:1 with water.
Sprayed on, scrubbed in, left to soak then jet washed off, reapplyed as required.
I think using a hand wire brush would be difficult and time consuming. I used various sizes of wire wheels in a low powered drill to scuff away the factory underseal as required, and also to grind away as much of the rust i found as possible, before treated.
Bought "Krust" (brand name) rust treatment, zinc primer (brushable) 1 litre tin, Seam sealer (brushable) 1 litre tin, standard grey aerosol primer, and top coat (red) cellulose aerosols from local paint factors, suppliers.
Treatment went like so:
Scuff away underseal, grind rust
Apply Krust rust treatment by brush, let dry
Apply zinc/etch primer by brush, let dry
Apply seam sealer by brush, let dry, re apply if you need to build up the thickness.
Then paint
Havent worked out exactly how long it took me on mine, but it was spread out over a least a month
tonybtonyb
Post Mon Jan 11, 2010 12:19 am
Can't wait to see the end product :cool:
scott180gtb
Post Mon Jan 11, 2010 12:11 pm
Paul
I can only find Kurust which is a hammer rite product. Is this what you used?
Cars
jaymos
Post Mon Jan 11, 2010 12:35 pm
scott180gtb wrote:Paul
ye krust is the hammerite one
scott180gtb
Post Tue Jan 12, 2010 1:47 pm
Has anyone got a parts list for all the Tech clips and fixings. Its taking far too long looking for stuff on Real OEM. Please help!
Cars
Post Wed Jan 13, 2010 3:57 pm
This one's all my fault as he hit the deer after dropping me off home after a meet :)
Get stuck in lad :D
scott180gtb
Post Sat Jan 30, 2010 9:40 pm
A quick update. I have been under the beast cleaning off the under seal and treating with Fertan. Lots of rust hence the re-shell questions.
Cars
Dan320is
Post Sat Jan 30, 2010 9:54 pm
If you want to spped up the underseal removal, you can use a blow torch to soften it and it comes off so much easier.
scott180gtb
Post Sat Mar 06, 2010 9:23 pm
A quick update. I managed to drop the donk out of the sport in true scrap yard fashion. :D
Lifted the shell on top of the donk before lifting it out onto the front lawn in front of the living room window. It helps having two 20 stone little brothers :mad:
Not long before a divorce is on the cards me thinks :cool:
I have been busy building up my recently purchased 2.8 stroker. I have lots of powder coated wrongness to share with you all in good time.
scott180gtb
Post Sat Apr 03, 2010 10:17 am
As promised some pictures of the new M20 2.8 stroker. Lots of powder coated wrongness and lots of new bits. I can’t take any credit for building this. It has been put together by beardymat. All I have done is swap over the gearbox and ancillaries from my old donk. There is something so right about a clean M20. I have added a BBTB and had the fannymold skimmed to make sure it’s nice and flat. I would have liked a BTB but funds don't allow at the minute. The injectors are getting cleaned as we speak then this will be all wrapped up waiting for the body. :D
I replaced the gearbox input shaft seal as the bell housing was full of slimy oil. A new crank case seal as well should take care of this. The box was cleaned and mounted up with a new clutch of course.
Some more powder coated wrongness
I have also rebuilt the callipers with new pistons and seals. Some braided lines as well.
I’m cleaning out the garage and trying to move some stuff on ready for the final push on the shell before it goes to Matt’s. Lots left to do. I have to keep dropping onto youtube to keep motivated. M20’s rule. The End. winkeye
