My 89 325i (auto to manual swapped)
DmcL
Post Sun May 31, 2009 1:33 am
the shell/bodywork is in great condition for the year with barely any rust. she has 117k miles and a fairly well documented history, etc, etc..
car was an auto when bought but im converting it. also was thinking i might convert her to 5 stud hubs so i can fit a set of ET15 Racing Dynamics RGR's i happen to have laying around.
got an E36 318tds radiator which is more or less the same dimensions as the radiator on my 325i but about half an inch thicker and about 4 inches wider.
since the gearbox is off an older model with no harmonic balancer i can run a Z3 M Coupe shifter for uber short shifts but still with a nice OEM feel. also replaced the joint, foam washer, etc.. on the selector shaft that comes out of the back of the box to further tighten it up. shift throw is atleast 50% shorter than stock and with the new support arm, joint and associated parts there is only about 1mm of side to side play in neutral. wont feel like the usual E30/E36/E46 5 speed floppy dildo lol
pedal box swap. not too hard just tricky to get at things back there.
wires joined in order for the car to start without a park or neutral signal from the auto. also nicely heat shrink wrapped and joined to the standard reverse light switch plug.
since buying her i have changed the timing belt and tensioner, waterpump, alternator/waterpump V belt, camshaft, inlet manifold gasket, sparkplugs and leads, distributor and rotor arm, new throttle cable, new reverse switch and brake switch, cleaned ICV, new TPS, new Mahle oil filter and oil changed, all 12 rocker arms replaced with new and eccentric lobes set to 0.30mm clearance with engine cold, new spigot/pilot bearing, new clutch kit, new clutch master and slave cylinders and all hard pipe and hoses, new trans mount bushes, new propshaft centre support bearing and carrier, new front drop links and ARB bushes, new fuel pump.
mods to the car:
venom motorsports chip (7k limiter)
BMC intake
NGK copper cores
E36 318tds radiator (to be fitted)
auto to manual swap
4.10 differential (gives me the gearing of a 316/318i, she will chirp tyres into 2nd in the dry lol)
AP clutch kit
Z3 m coupe shifter with extended support arm, UUC motorwerks weighted gearknob
also today i gave the car its first proper clean since i got it. was too dark for pics by the time i finished tho so more pics up soon as i get a chance to take them lol
i know the 14's kill it.. i have 325 sport bbs cross spokes in the works. also will be lowered sometime too winkeye
WMMotorsports
