I thought id take some pics of the tool and different stages of using it as it might help someone some day
The tool kit with instructions on how to make the tool to what u need to do
You put the kit together to make up the puller and installer
Bush puller made up
The bush puller in use
On this pic it shows how the puller has a metal lid that locks around the top of the bush that pulls it out
On this pic u can see how the device also uses the sill of the car for the removal tool
The bush installer made up
The bush tool installing
If u look the lid of the tool overlaps onto the rear beam for better pulling
Once pushed all the way in it looked like this
All in all a cracking tool, but to be honest all though I was using the tool it was a still a bitch of a job as the metal collar on the old bush on the left had corroded to the car and took a lot of swearing and smashing to get the beam to drop down however with out the tool there is no way I could of done it
