On Thursday afternoon I went up to make a start. I had already previously removed the carpet as there is a water leak and the carpet was getting wet, so that has been dried and sitting in Mum's conservatory!!
who ever replaced the Tech 1 spoiler with the Tech 2 item didn't put the material to prevent it rubbing on the boot, as it is almost through to bare metal at one point.
On Friday I done the Passenger door, started on the sunroof(had to cut all of the sealant out for this, great fun), then started on the front and sills
The sill weren't as bad as I was expecting, my uncle who replaced the front wing said they were really bad and I should maybe consider selling the car, but I couldn't do that
Usual front jacking point...
Bumper off....
Front valance...
This must have been replaced at some point as there were two bottom bolts missing and these...
I might investigate this, see what I can find out...
And that's where I'm up to at the mo, I've still to remove the dash, but I'm going to remove the PAS fluid and coolant so I'll drive her outside for that then I'll get stuck in to the engine bay next week!!:D
ta ta for now!!
