my e30's * update m50 projects begining
gcs325i
Post Sat Aug 23, 2008 7:40 pm
hi folks been on here for a while now so thought i'd share a few pic's and spec/plans. First off was the 325, got it when i was 18 loved the power and sideway antic's on the roundabouts. :D It was quite the change from the 1.5i jap crap i first had and ministock i drove in my younger days (10-16).
89 325i req loads of welding, floor, inner arch's rear, towing eye area ect. this is it after finishing it and respray
Currently running hottuning manifold,goodridge hoses, H&R anti roll bars, bilstiens, rouge enginneering top mounts, powerflex bushes all round, except trailing arms which are superflex. The rest of the running gear was either serviced or replaced, depending on condition.
next up was a 316i which a mate was going to scrap because he put engine oil in the power steering and wrecked the seals?? but the shell is mint so i stripped it ready for a reshell or a cheap cage and decent powered engine to turn up.
engine in....
engine out!
lastly is a 320i i picked up from edinburgh for the sport seats but turned out to be to good to scrap/frag so i started to prep it for a respray and got a couple of wings for it.
This is now going to get a new tank and a fully poly'd up disc brake back end i have lying about as soon as i get some more goodridge hoses.
lastly random pic of the work shop :D
cheers for looking
gaz
aj_mckay
Post Sat Aug 23, 2008 8:07 pm
Looks like you've had some good fun there and produced some fine looking work as a result!! Nice work. Is that your own workshop or somewhere you work? Very envious if it is yours... 8)
Post Sat Aug 23, 2008 8:21 pm
+1 mate - Impressed with the cars and the workshop as well - must be great to have all that space and a 4 post lift.
Post Sat Aug 23, 2008 8:27 pm
+1 would love a workshop that size with a 4 post in it keep the progress pics coming :) is the first pic Lachs silver ?
gcs325i
Post Sun Aug 24, 2008 11:57 am
cheer guy's, the place is my dads but we share the ramp time with totally different results, he builds offroaders i prefer the dropped well handling e30's. The first one is lachs the others are bronzebeige varients. I will take more shots of the 320 suspension rebuild, plan is to use the 325i anti roll bars, a disc brake back end m3 lower front bushes and new petrol tank will be done at the same time. Anyone know if 320's had the bigger 51mm front struts or the smaller ones?
Also will get a few shots of the new sport interior, tech 1 steering wheel, and finished paint job.
The_Diddler
Love it up the more door !
Post Sun Aug 24, 2008 12:22 pm
i'm pretty sure 320's have the smaller 41mm struts up front
gcs325i
Post Sun Aug 24, 2008 12:53 pm
The_Diddler wrote:i'm pretty sure 320's have the smaller 41mm struts up front
Cool thats what i thought, i'll pick up a proper set for it.
gcs325i
Post Tue Aug 26, 2008 10:17 pm
just a quick update of the 320i painted and sports seats fitted, cheers rossmc88 for the seats.
bonnets still needs set to match the pattern wings as best as possible.
disc brake back end ready for fitting, diff getting changed for the 'big diff' off the 325i as picked up a 3.64 lsd for that today from gepetto/andy, cheers man!
was going to fit tonight but will change the oil and fit z3m bush first then fit it and give it a test on the way to pick up a set of front struts from up north at the week end
Post Tue Aug 26, 2008 11:24 pm
some nice cars there :cool:
good luck with fitting diff :thumb:
btw who were you insured with at 18 in the 325. Cheapest i can get is with direct line @ around £1700
gcs325i
Post Wed Aug 27, 2008 12:13 am
cheers man, yeah the diff should be straight forward enough (hopefully) had a couple different one's in there but still a healthy lift on your own. :)
Think i was about £1200 as a named drive for the first year on the named driver builds no claims bonus thing they run. Not the greatest way around thing's but starting to get better now 21 and £400ish for the 320i, £600ish for the 325i which is still steep but should get better.
MartC
Post Wed Aug 27, 2008 5:28 pm
Wish I had some facilities like that mate. Looks like you've built yourself a spray booth as well there 8)
gcs325i
Post Wed Aug 27, 2008 6:35 pm
MartC wrote:Wish I had some facilities like that mate. Looks like you've built yourself a spray booth as well there 8)
yeah man, a sign writer had rented the front of the shed and built the booth a few years ago. I'm lucky to have the use of these facilities, i think we are moving the booth over the winter so the project car will either be on hold or finished by then.
GrindCulture
Post Wed Aug 27, 2008 6:39 pm
Looks like you've got enough to keep you busy for a while there mate :D Having a workshop like that to use is a Godsend too.
Not in E30s any more :(
shedrool83
Post Wed Aug 27, 2008 8:27 pm
Two nice E30 you have there :cool:
Did you do the painting yourself?
One lucky guy have the workshop.
gcs325i
Post Wed Aug 27, 2008 9:43 pm
cheers mate, i didn't spray the outside of the body's, my friend Ralph did them both. I did the prep on the bronze one and the engine bay on the lachs one. Will be changing the colour of the 316 so will tackle the paint work on this one myself after i get the req parts/money for engine ect. :)
gcs325i
Post Thu Nov 20, 2008 9:35 pm
Thought i would update what I've been working on of late. After sorting the suspension on the 325 it's time to get the brakes in order, so picked up 280mmx22mm discs and a set of 4 pot calipers and started a rough layout of how it'll go together.
Just got to get some suitably thick steel and proper spec bolts for the brackets and get them tapped and they'll be done. Then that just leaves the back brakes to be sourced and fitted then it's time for a bigger engine.
shedrool83
Post Thu Nov 20, 2008 9:42 pm
Looking good mate :cool:
BadDave
Post Thu Nov 20, 2008 9:50 pm
Looking good so far Gaz
Might i make a small suggestion
Make the template for the caliper bracket from MDF or other suitable block of wood then transfer it to the steel or aluminium plate and make sure the caliper bracket is AT LEAST 1/2" OR 13MM THICK
:thumb:
gcs325i
Post Fri Nov 21, 2008 1:49 am
shedrool83 wrote:Looking good mate :cool:
Cheers Jake it's coming together.
Dave going to see my friendly local machinist tomorrow/in the morning, going for 15mm steel tapped to m12x1.5 , so hopefully he'll give me a good price as i won a load of trophies for him back in the day :D
Post Thu Nov 27, 2008 7:24 pm
Brakes look good, what size wheels will you be hoping to use?
BadDave
Post Thu Nov 27, 2008 7:28 pm
DanThe wrote:Brakes look good, what size wheels will you be hoping to use?
15's IIRC poss 16's
gcs325i
Post Thu Nov 27, 2008 7:40 pm
As Dave said hopefully 15" bbs or some 16" rim's all depends on what i find in the shed and what fits offset wise. Also been looking at getting a set of banded 15" steels.
Also got the rear brakes sorted, 280mm disc's with m3 calipers. Got a m3 master cylinder to fit as well to make up for the increase in piston size and number. Will get more pictures up when the parts arrive.
Post Thu Nov 27, 2008 8:21 pm
VW discs?
shedrool83
Post Thu Nov 27, 2008 8:24 pm
Gary i've got 16" with 35 or 38 et (cant remember) if you want to try them for size.
gcs325i
Post Thu Nov 27, 2008 8:31 pm
DanThe wrote:VW discs?
VW front disc's machined to fit, Z1 rear straight fit utilizing the standard hand brake.
Jake I'll definitely take you up on that offer when i finish the caliper brackets
e301988325i
Post Thu Nov 27, 2008 9:28 pm
First off nice cars and very nice 4-poster I want one!!!
What front discs are you using VW G60??
I've got that rear brake setup, have you got the E30 M3 rear caliper carriers as well? They will need machining to fit too.
I said:
e30topless said:
lock the wife in there
gcs325i
Post Thu Nov 27, 2008 9:36 pm
Cheers mate, yeah I'm using the G60 discs. The rear's are complete calipers and carriers, haven't arrived yet but shouldn't be to hard to get them to fit. What setup are you running on the front?
e301988325i
Post Thu Nov 27, 2008 9:55 pm
For your back brakes I recommend getting the E30 M3 disc protectors, will make a much better job.
I'm running 4-pot wilwoods, g60 discs. . . from the outside of the disc face to the inside of my 15" BBS is only about 30mm but I will measure if you want. This should let you know whether those calipers will fit behind the front wheels or not! Doesn't look like it to me!!! My wilwoods are so close you wouldn't believe!!!
ps) there are a couple of threads about that rear brake upgrade. . . If you need any info give me a shout.
Cheers Alex
I said:
gcs325i
Post Sun Dec 14, 2008 12:50 am
caliper brackets done!
Got Z1 discs on the way and received a set of reconditioned M3 calipers and carriers from the US so the back is sorted.
But
Thinking of selling up everything at the moment so there may be a large for sale thread in the new year :? but I'll try finish these first then decide.
shedrool83
Post Sun Dec 14, 2008 9:20 am
Why you thinking of selling up mate?
e301988325i
Post Sun Dec 14, 2008 9:58 am
gcs325i wrote:Image
But
They look nice! What have you made them out of? Are those stainless bolts?
I said:
gcs325i
Post Sun Dec 14, 2008 12:44 pm
They do, pity I cant take any credit for them. Brackets - 25mmx15mm steel. Bolts - high tensile 12.9 zinc coated m12x1.75
e301988325i
Post Sun Dec 14, 2008 6:47 pm
That'll do nicely then, don't sell up it'll all be worth it the first time you start floating, zero gravity style in the belts!
I said:
gcs325i
Post Tue Dec 16, 2008 12:43 am
shedrool83 wrote:Why you thinking of selling up mate?
Slight fall out with the owner of the shed :o
Some better news is that these arrived :)
They look a good bit bigger
shedrool83
Post Tue Dec 16, 2008 5:52 am
Thats a bummer for you mate you have a great set up there.
