Warning X-rated
[url]http://imageshack.us]
[/url]Rear drivers side inner arch complete with big hole
[/url]http://imageshack.us]
[/URL]Lets look at that a little closer
[/url]This is (one) of the MOT failing points - v dangerous top mount
[/URL]Behind this arch it doesn't get much better
[/url]Passenger rear inner arch, bad, but not as bad...
[/URL]Engine bay horrors Pt 1
[/url]And Pt II, a bad but successful patch up jobbie.
The actual failing points were all 4 suspension mounts but everything else was ok for the MOT
There is very little exterior rust, what I found I got it cut out or bought replacement panels and removed but I hadn't appreciated the extent of the corrosion in hard to examine places and annoyingly each bodyshop I took it to told me it was sound -
Now add that the sills and jacking points need done and whatever other horrors are lurking where the eye cannot see this sadly is soon to be an ex-E30...
Has anyone seen or even saved worse?
