T-cut test... Now with pics of the touring
stonesie
Post Sat May 10, 2008 11:56 pm
Well it wasn't suposed to be a test but there was much less in the bottle than i thought :o:
It got the T-cut, then Autoglym super resin polish (not much of that either) followed by some turtle wax tech wax stuff that was on special
Big pic
http://img.villagephotos.com/p/2004-2/6 ... CF0037.JPG
It came up better than i thought so im off to halfrauds to re stock tomorrow, polishing cloth is white now though 8O
stonesie
Post Sun May 11, 2008 12:04 am
The pic hasant uploaded too well... but you get the idea, I think its been a few years since its seen polish.
AdamG
Post Sun May 11, 2008 3:36 am
T-cut is nasty stuff, I wouldn't reccomend it.
If you are trying to get rid of Swirls and light scratches, try something like Meguiars Swirl Remover.
If you just need to bring the paintwork up a bit then some of the poorboys stuff is very good.
Post Sun May 11, 2008 6:35 am
I've used it for years - as long as you don't rub too hard or use it with a mechanical mop and follow up with a decent polish ( Like Autoglym ) I've always had good results with it. You can polish a turd after all......... winkeye
Post Sun May 11, 2008 7:23 am
T cut has been around since the year dot and IMO is still the best readily available cutting agent. You just have to be careful with it. If you know how to use it, it knocks spots of the Auto Glym Paint Renovator and the Meguiars Swirl Remover all day long.
aceraf
Post Sun May 11, 2008 9:48 am
stonesie wrote:Well it wasn't suposed to be a test but there was much less in the bottle than i thought :o:
Big pic
That's because t-cut strips the top surface of the paint off. I wouldn't let that anywhere near my car.
You can achieve the same results without removing all your paint with other products.
Have you applied some wax over the top?
Breaking 325i Touring
stonesie
Post Sun May 11, 2008 1:14 pm
Yeah some turtle wax paste, im gonna go finish the job now i've bought more T-cut, the pic's been compressed so it dosent really show what a matt finish the paint is....... i like it shiney :cool:
Still need to find somwhere local to doncaster that will sort the rust spots without chargeing a fortune too.
Post Sun May 11, 2008 1:47 pm
I've tried other stuff, such as the Meguiars and it don't come anywhere near to doing the job t-cut does
Post Sun May 11, 2008 5:03 pm
And quite rightly so considering the car in your sig pic is metalic with a clear top coat finish. On a white, solid black or any other solid colour T Cut is perfect if only in moderation.
d6dph
Post Sun May 11, 2008 5:34 pm
T-cut can give good results, but it is a crude method imo.
Also you must seal the paint with a wax or sealant to prevent fading.
stonesie
Post Sun May 11, 2008 6:57 pm
Well to say im not the best at polishing cars, and it had vertually no reflective propertys at all this time yesterday...........
Im happy :cool:
Need those rear arches and a few other bits and bats sorting before i go buying a machine polisher....
jaistanley
Post Tue May 13, 2008 1:26 pm
On a particularly bad red car I've been known to flat the whole thing over with P2000 paper, then Tcut and a fine buff with G13 then Autoglym. Sounds very drastic but it cuts off all that crappy faded paint. Then a quick wax and it'll look good for ages. (well as long as a brilliant red ca can look good anyway...)
Top work mate. Bit of TLC and she looks a lot fresher.
Post Tue May 13, 2008 5:49 pm
Looks great Stonsie - definately worth the effort. White E30's are :cool:
