Goosie's S50 Moredoor, 'Ring action
goosiegander
Zonegoose
Thu Oct 25, 2007 3:44 pm
been quoted 160 for repairing/respraying it, or i could botch it myself, shaz did a damn good job tho
not sure about the finish i got -may just rub down the skirts again, fill the tech 1 lines and try again, failing that do the prep work myself then have the body shop paint them...
josh-hocking
Teenager with Taste !
Thu Oct 25, 2007 3:46 pm
yours dont look that bad on the pic!
goosiegander
Zonegoose
Thu Oct 25, 2007 3:52 pm
My camera seems to be able to make red look pink! the finish isn't brilliant to be honest but then i never pollished them back afterwards so that would have made a big difference, need to find a decient diy spray/prep/polishing guide
josh-hocking
Thu Oct 25, 2007 3:55 pm
just get some 1000 wet and dry...rub down and buff up!! they'll look great :D
goosiegander
Zonegoose
Thu Oct 25, 2007 4:03 pm
what should i be rubbing them down with? fairy liquid? what about polishing compounds afterwards? :)
josh-hocking
Thu Oct 25, 2007 4:43 pm
get the sandpaper ....dip in loads of water.....then sand till smooth but dont go though paint.......then buff up using any polish. :D
josh-hocking
Thu Oct 25, 2007 4:44 pm
i recomend to atart with autoglym paint renovator,then used some mequires polish
maxfield
Thu Oct 25, 2007 5:00 pm
Sand paper :eek:
Get a good surface key, 800? grit wet and dry should do it, use plenty of water and fairy liquid. Clean up the surface and get it dry then go over it with primer give it an hour another layer or primer, not sure whether it's best to let it dry completely or till it's pretty tacky, and then spray 1 layer over it, pretty thin, then a medium layer, then another medium layer. Wait for a few days in a hot place, go over it with loads of water and fairy liquid with some 2000 wet and dry then a polishing compound, I think it's called G3.
oakey
Thu Oct 25, 2007 6:31 pm
Rub the skirts back with 800 wet and dry until 'orange peel' is flat.
Spray again with paint but do thicker coat so that the paint lays down flat on the panel.
If you havent slapped on alot of coats of red just rubbing back and using compound could take the paint back too far.
Going over it with a few coats good of lacquer could possibly sort them out. Spray the paint/lacquer on thick enough to make the area look 'wet'. Looks to me like you have been too 'conservative' with the spraying :wink:
josh-hocking
when said sandpaper i ment wet and dry if you look on previous post :D
goosiegander
Zonegoose
Sat Oct 27, 2007 11:32 pm
Very helpful guys ta! :D
Well ready to start the prep work,
Sanding back the white is gonna be really tedious...
There's a bit of flaking there,
looking like a bit of a mission,
Gonna do the prep work then spray later on do i need to take it back to primer or just a good smooth keyed surface for primer?
still need to prep and prime the other skirt as yet and I've decided to fill the strips in to try and harmonise the thing.
Any further thoughts guys?
goosiegander
Zonegoose
Sun Oct 28, 2007 1:34 pm
Oh and by the way the original paint is peeling off -will this have much impact on the prep work?
whipsey
Sun Oct 28, 2007 1:36 pm
do you have access to a powerful air line or a jet wash?
aceraf
Sun Oct 28, 2007 1:41 pm
If the paint is flaking, then i suggest rubbing all back down to the point is flaking to (if htat makes sense). It'll mean you have to do less rubbing down of the high-build primer to get a perfect finish.
Breaking 325i Touring
goosiegander
Zonegoose
Sun Oct 28, 2007 1:58 pm
cool -shall i jet wash the flakey rubbish off then chaps?
whipsey
Sun Oct 28, 2007 1:59 pm
it should get rid of the majority of it air line would be better imo but jet wash should work fine
Onz
Wed Nov 14, 2007 11:30 pm
well done, good luck dude :)
goosiegander
Zonegoose
Wed Nov 14, 2007 11:38 pm
Cheers dude! this thread has been going on for ages now, trying to keep it halfway interesting, maybe i need to spice it up with some naked slags... ahem...friends rubbing down/cleaning parts? winkeye lol!
320imoredoor
Wed Dec 12, 2007 9:59 pm
Looks cool. I is doing the exact same with my 'more door' but i want it to look standard on the outside but have all the trick suspension under & a tidy interior.
Keep up the good work mate & make sure you keep us posted
Looks deadly already
Standard m-tec VS Track weapon m-tec
Jay07
Sun Jan 06, 2008 2:56 pm
Good to see that the project is progressing mate! Well done!! :D
Where did you get your carbon badges from? I bought some but the rear one wasnt the same shape as an original badge (it didnt have the extra chrome bit to make up for the curve of the boot, if you know what i mean) Instead they just sent me two of the same front ones! Hense it didnt fit :(
Did you dechrome/spray your windows?
I wish i had seen that thread about changing the seat covers before xmas. I had a real B!tch of a time changing mine. Its easy when you know how but for a while it was really doing my head in! But thankfully Brian came to the rescue!
I've bought myself some se skirts from Adi which are waiting to get on...i think i'll leave them plastic black without spraying. Similar to you i'm going to avoid drilling holes into the panels. I have the bottom clips, someone suggested windscreen sealant for the top join!?
Cant wait for winter to pass so i can get back out there and finish the wing off!!
Was v.impressed to see you went for the 2.5 convo!!! NICE... how did that go? All done and working fine?
goosiegander
Zonegoose
Tue Jan 15, 2008 1:07 am
cam cover prior to the strip and refitting the cylinder head/six branch
not sure how long the finish will last but once its all back together i'll feel good for a few days lol!
goosiegander
Zonegoose
Tue Jan 15, 2008 1:29 am
oh and the rocker cover
And thanks for the comments chaps -yes the 2.5 is going like a dream the carbon badges from ebay were fine for fitting straight on, the windows were dechromed as standard, still no fitted skirts lol!
jbh
Hartge Crew
Tue Jan 15, 2008 1:42 am
lookin good chris keep up the good work
goosiegander
Zonegoose
Sun Jan 27, 2008 12:00 am
I just spent 2 days changing the cylinder head and making things better generally, pictures tomorrow lol! :D
Jay07
Sun Jan 27, 2008 10:15 pm
looking forward to them mate!!
konrad565
Tue Jan 29, 2008 3:40 pm
Now I know red is a much loved e30 colour but if I'm honest I'm definately not usually a fan but there is something about yours that is really really nice. Good work she's coming along very nicely!
(even though in some of the pictures she does look pink :P )
goosiegander
Zonegoose
Thu Jan 31, 2008 12:30 am
finally got it into Peter's today
6 Branch fitted along with new master and slave cylinders...
Fu*k yeah!!! :D
oakey
Thu Jan 31, 2008 12:42 am
Is that another hottuning manifold?
They do look good 8)
goosiegander
Zonegoose
Thu Jan 31, 2008 12:49 am
hottuning manifold yes sir it is,
definate noticable difference feels like the car just came into its own, coupled with the 'zone chip' courtesy of Ant, i couldan't be happier, well not much anyway :D
Jay07
Thu Jan 31, 2008 10:59 am
Wow! Very nice work mate... That engine compartment is starting to look sexy.. Who does the garage belong to? That must come in real handy winkeye
aceraf
Thu Jan 31, 2008 11:17 am
That engine bay is looking good.
Any plans to dyno it? Would be interested in what it's putting out.
Looking good! :thumb:
goosiegander
Zonegoose
Thu Jan 31, 2008 1:11 pm
yes there is a dyno plan on the cards but not till i get back from sea, theres still a few bits to go into the bay as yet but again its going to have to wait until i return. The garage in question is Spot on Tuning, and a big thank you goes to Peter for staying well past time to get the job finished, think its fair to say the car has come a long way
1an
Thu Jan 31, 2008 2:46 pm
so what does it sound like with that manifold and is i a scorpion you also have on there?
goosiegander
Zonegoose
Thu Jan 31, 2008 6:27 pm
yes full scorpion dtm now, it sounds pretty damn sweet to be honest, not too loud just a nice rasp -i'll try and bring it down to lakeside in march/april :D
1an
Thu Jan 31, 2008 6:38 pm
thinking of getting myself one of those manifolds, aswell as they look awesome and appear to make a nice noise for not alot fo money to be honest.
