zd3bx's 1990 E30 325i SE Black Saloon Project Thread
zd3bx
Sat Aug 16, 2014 6:25 pm
Hey everyone, been a while, almost forgot I had a project thread in here lol :D
Put the car on a ramp last week to see what was happening underneath and took some photos of the rear end, which is probably one of the last major jobs that needs doing.
Here are some pics:
The trailing arm bushes are crying for a change for sure...
The diff mount doesn't seem too bad, but obviously worth changing while you're there, replacing the trailing arm bushes:
And of course the rear ARB links and bushes, mine are clearly past their best:
So yeah, haven't done anything lately, just waiting for "the right moment" to do the rear suspension or maybe sort a few little things on the front first, like the pissing steering pipes and replace track rod ends + wheel alignment...Will see what happens and I'll make sure to have my camera ready :D
By the way, let me know if there's anything else I should do at the back, as I've got on my list: trailing arm bushes, subframe bushes, ARB links and bushes and diff mount? Hopefully not missing anything?
I'll get the shocks/springs sorted later, so not worried about that yet...I think that's it.
Talk to you soon.
Mitchen
Sat Aug 16, 2014 10:06 pm
Great read. You're pretty much dealing with yours the same way I am. Working your way through it slowly but surely. It's amazing how the money adds up!
1990 320i Coupe SE
viewtopic.php?t=253048
zd3bx
Sun Oct 12, 2014 1:30 pm
Can't believe it's been almost 2 months since I last updated this thread...Anyway, I bought some parts getting ready for the rear suspension overhaul, but before that I'm going to get a few little things sorted first.
You can see I've got the rear subframe bushes and the rear arb links here, all Lemforder, of course. And the main thing I was after were the track rod ends, because I want to replace them while I'm putting a new UJ for the steering.
By the way, the bushes, links and the rods were from ECP for roughly 90 quid with an online discount. Not too bad...
The part number for the UJ is: 32 31 1 153 993
I got it from BM Mini Parts for about £16, plus some bolts and nuts as well. All genuine BMW.
Really recommend these guys > http://www.bmminiparts.com/
Still need to buy some more stuff for the rear, like trailing arm bushes, etc, but hopefully I'll get the steering sorted this month and then the rear suspension next :)
Stay tuned!
zd3bx
Sun Nov 02, 2014 8:25 pm
Okay, finally managed to get some work done last weekend. Well, slow and steady wins the race :D
So here's what we've done. Replaced the track rods, as mine were completely knackered:
New Lemforder ones fitted on both corners:
Then we've replaced the UJ rubber and now there's no more play in the steering - feels so unusual after over 2 years of driving with that huge play...Came out pretty easy, just had to drop the steering rack slightly.
After that was done, we slightly trimmed the edges of the P/S pipes and put new clips in there to stop the leak from under the reservoir. Drained and flushed the system, then filled it with Valvoline green power steering fluid (you need roughly 1 ltr).
And in the end, we put new genuine BMW belts for the A/C and power steering. Previously I had Continental ones from ECP, but somehow the A/C belt managed to turn over and it was spinning on its back with teeth on top...No idea how it happened. Also compared to the BMW belt, it was narrower as well.
The current Continental P/S belt seemed to be a bit too long, so anyway I put a genuine BMW one there too. Do it once, do it right.
Obviously, after changing the track rod ends, I needed alignment, so I went to GoldenWheel in Park Royal to get it done. A quick snap:
Now all the little things are done, most likely the next job will be the rear bushes with ARB links, etc, but I might get the sills done first to make life easier later on. Sort out the rust, so when I'm changing the subframe bushes, the side brackets and bolts will be simple to remove/re-fit.
Stay tuned and you'll find out first whatever happens :)
Any tips/advice for future work much appreciated. Thanks.
pikanibbles
Sun Nov 02, 2014 9:05 pm
Love reading your updates. I've carried out on my own 325i pretty much all of the work that you have on your's, and a few extra things besides, using all genuine or OEM branded parts. These maintenance items are what make the difference between a rough car and a nice example. It's a largely thankless task in that it's mostly unseen work that adds little to the car's resale value. I know these cost are unrecoverable, but I don't plan on selling mine any time soon, and I find it rewarding rectifying all of the small issues and as it's my daily driver I like to keep it in tip top condition mechanically. Wish I'd started a blog to document it though as all I have are receipts and invoices, but they don't make for as interesting reading on a Sunday evening.
Keep up the good work.
zd3bx
Sun Nov 02, 2014 9:15 pm
Thanks mate, indeed when you work on replacing all the mechanical/maintenance parts, it doesn't show on the outside, but when you drive it, that's when you know it was all worth it :)
The car looks pretty much exactly the same as I bought it 2 years ago, but the amount of work that we've done under the bonnet and underneath the car is quite a lot, yet we're still not finished...
Same here, I use it as a daily, so it has to be in top mechanical condition. I see no point in spending silly money on wheels and body kits, when the car doesn't drive right, so first things first!
milescook
Sat Dec 13, 2014 11:49 pm
zd3bx wrote:Thanks mate, indeed when you work on replacing all the mechanical/maintenance parts, it doesn't show on the outside, but when you drive it, that's when you know it was all worth it :)
Well said that man - subscribed :D
Edit - ah, turns out I was already subscribed :o:
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
zd3bx
Tue Dec 23, 2014 11:22 pm
Right, got 2 weeks off for Christmas from work, so will try to sort out a few little things over this period.
My cluster illumination went on the right side recently, so one of the jobs was to get the cluster out and replace the bulbs. Did it few days ago, so here are a few pics and some tips.
First, we'll need to remove (or just lower) the trim above the pedals. It is held by a couple of a plastic twisting screws, which you can see on the pictures below:
So there's 2 on the driver's side and one on the left. There should also be one right under the steering column as well, but mine is missing:
Then there's a clip that holds the left side of the trim, where it just slides in, and there's something similar on the right hand side above the pedals, but it's more like a metal holder.
If you don't have headlight height adjustment, then you can probably just slide out the trim and put it on a side. However, I didn't want to mess around with disconnecting the adjustment on mine, so I just lowered the trim to have enough access above. Not sure what's the unit left of the adjuster...
The next step is to remove this plastic piece, which hides a couple of screws that hold the cluster surrounding trim. This piece is held by 2 silver knurled nuts, which are a bit hard to reach, but should be hand tight.
You can see how it all looks like from behind in the picture below. One of the nuts was really tight on mine, so I sprayed some WD40 on it before it budged. When you get the nuts out, carefully push on the threads to get the trim out. And keep an eye on those tabs in the middle, not to break them.
Would be useful to clean up those threads, before you put the trim back, so next time the nuts will be easy to come out, if you need to go there. Once the trim is out of the way, you'll see 4 screws behind.
The 2 silver ones in the middle and very short, so careful not to lose them, and 2 on the corners also hold the trim for the cluster.
Now remove the 2 screws from the top of the trim and you can take it out. As usual, it's a fragile piece of plastic, so take care.
And the last 2 screws that attach the A-shaped holders to the dash on each corner, before we can move the cluster.
The next part is probably the most difficult, because you have to carefully tilt the cluster facing down, while also pulling it towards you. What you want to do is rest it on its face, so you can get access to the plugs behind it.
Watch those A holders - you can use them to pull the cluster towards you, but be gentle :)
I found it easier to slightly pull out the left side of the cluster first, so I could remove the white plug:
DISCONNECT THE BATTERY BEFORE REMOVING ANY OF THE PLUGS
Getting the blue one out and putting it back in was probably the hardest, as the wiring is very tight on that side, so it's a bit fiddly.
However, once the blue out is out, you don't even have to touch the yellow one, as the cluster easily comes out far enough to replace any bulbs/tighten the fuel/temp gauge nuts, etc.
This is how the plugs come out. You have to pull up the black plastic bit with a flathead screwdriver and then wiggle the plug out. It's easy to break the black holders, so don't go crazy with the screwdriver - push it slightly up, then pull by hand.
Now there's plenty of space to replace the bulbs without having to completely remove the cluster. The big black socket you can see below holds the illumination bulb for the right side of the cluster - just twist anti-clockwise to take it out.
While you there, also tighten the small nut for the temp gauge - it's a 7mm.
The bulb on the other side was ok, but I decided to replace it anyway to avoid going through the same process in the near future. Same thing here, you can tighten the nut for the fuel level gauge.
You'll need two 12v 3W bulbs for the illumination. I got mine from Halfords - 2 quid each, they better last long :D
The next thing I'm planning to do is to replace the wiper motor, so hopefully will get it done this week and take a few pics for you :) I also bought an aerial quite a few months ago, but still haven't managed to fit it, so might get it done too.
zd3bx
Sun Jan 11, 2015 7:21 pm
With the cluster sorted, the next job was to replace the wiper motor, which had the common intermittent mode fault.
I managed to order a brand-new genuine BMW/Bosch one from BM Mini Parts for £90, which was good value for money, imo.
And I'm glad I did, because as you will see later, I doubt my original motor was worth refurbing...
Here's the new motor in all its glory:
Ok, so the first thing that needs to come out is the passenger side air vent. It's a fragile thing and very easy to break, especially because it's very old. I would suggest spraying some WD40 around the edges of it when removing/fitting, as it helps.
What you need to do is push down from the top edge of it, while simultaneously trying to pull the top out. It won't come out all at once, so I managed to pull out the right-hand side top first and then worked towards the left to clear all the clips.
In the picture below, you can see that there are 3 flexible metal clips at the bottom, which allow the vent to be pushed up/down, and there are 4 plastic tabs at the top, which hold the top bit.
Assuming your wipers are in the normal parked position, after you have removed the air vent you are going to see something like this:
As you can see, the nut that's holding the linkage to the motor is not easily accessible, so what you need to do is turn the ignition "ON", run the wipers and switch the ignition "OFF", when they get to the vertical position, meaning half-way through the cycle.
Now the linkage will look like this, allowing you to remove the nut:
However, BEFORE you remove the nut, make sure to mark the linkage position, so you'll be able to put it back exactly as it was once you are finished. I simply scored a line with a screwdriver along the small linkage arm and the bracket of the motor.
It doesn't matter how you do it, as long as you make an indicator for yourself to know how to put it all back in the original position.
Get the 10mm nut out (careful, there's a small washer as well) and just push the linkage to a side. Unfortunately, in my case, it wasn't just the matter of removing the nut and praying off the linkage, because the arm was really stuck to the motor. After spraying tons of WD40 on it and some fighting with a flat screwdriver and a hammer, it finally came loose. Mind you, I butchered the wiper motor cover a bit in the process, which you will see later.
Now the next thing we need to do is to slightly pull out the sound deadening/insulation panel on the firewall, because it's hiding one of the nuts that holds the wiper motor bracket.
First, get the 2 screws removed that hold this plug to the panel. And then remove two bolts (I think 7mm) that hold the right hand side of the panel. You can see one bolt in the picture below, just right off the plug - the other one is just below the plug, slightly towards the left.
You will have to remove the bonnet rubber seal in the middle to allow the panel to come out. Keep in mind, the insulation material is attached to this metal panel. When you lift the bonnet seal from the top, you'll be able to see the edge of this panel and pull it out. There's no need to touch the insulation/sound deadening material whatsoever.
Once you are done, you'll see the nut for the bracket that wasn't accessible before. The clearance is very limited there, but I don't see a point of removing the whole panel, because you can simply pull it out slightly to get the motor in and out.
Now we are ready to remove the bracket, but first disconnect the wiper motor. Here's how you do it. The motor bracket has a small part sticking out from its side, which serves like a meeting point for both plugs. The wiper plug clips onto this piece and then the other plug attaches from the bottom. They are just push in/pull out, nothing special. Remember, how they are plugged for the future.
You'll notice there's a plastic cover on the left-hand side of the bracket, so once you have removed all the nuts, just lift up the bracket and get this piece out, as it sits under the same nuts.
The next part is probably the hardest...
I've read that people remove the bracket together with the motor, but for me it was easier to remove the 3 bolts that hold the motor to the bracket and get the motor out with its cover, leaving the bracket inside.
Keep in mind, you'll have to de-attach the motor's plug from the bracket - try to remember how it goes through, making re-fitting easier.
The motor won't come out from the air vent hole, so you'll need to get it out by pushing the sound deadening panel away, which creates a gap just about big enough for the motor to squeeze through.
So here's the state of mine:
And this is the cover that I "modified" slightly, when I was trying to remove the linkage arm from the motor in the beginning. I decided to re-use, because getting a replacement in the middle of Christmas wasn't an option...
That's it really. Once you have managed to get the motor out, most of the work is done and now you "should know" how to put the new one back. Clean the old cover nicely, snap it onto the new motor and squeeze it through the gap you've created earlier.
Once you've got the motor inside, you'll need to re-attach it to the bracket, while trying to keep the cover on, which can be quite tricky. Also remember to route the plug through the small hole on the bracket and clip it onto the metal holder.
With the motor and the bracket reunited, you can put everything back in its place, remembering to re-fit the plastic cover first that you removed in the beginning, which goes under the bracket. Tighten the nuts and re-connect the plug.
Put the linkage arm on the motor, aligning it with the marks that you hopefully made before removing it and re-fit the washer with the nut. Note, it's a wave washer, not a regular one, so I decided to replace it with a new one, just in case.
Wave washer part number > 07119932099
Hex nut > 07119905543
Yes, I'm so sad that I ordered a genuine washer and a hex nut from BMW :D
Finally, put the sound deadening panel back in, re-attach the plug and re-fit the bonnet seal.
However, before you get too excited, we have one more thing to do - aligning the linkage with the motor cycle. This won't be an issue, if you're refurbishing your old motor, because its cycle will be "in the middle", matching your linkage. So meaning, as long as you re-align the linkage arm correctly, then as soon as you turn the ignition on, your wipers will return to the park position and you'll be done.
The difference with the new motor, is the fact that it comes in the "parked" position, meaning if you run the wipers after fitting a new motor, they will park in the vertical position, because that's the position they were in, when we have removed the original motor.
There are a few ways to get this corrected.
You could remove the linkage arm and try to "guess" the mid cycle of the motor by running the wipers and then switching the ignition off after about half a second later. Then re-attach the arm and check where the wipers park...As you can probably tell, this will take a good while and it's not the best way to do it.
Alternatively, you could adjust the linkage manually by hand, but I had no clue to do that and didn't want to make matters worse, so I found my own method.
After fitting the new motor, I realized that my wipers were parking vertically, so after a couple of failed attempt to guess the mid cycle, I gave up and did this.
I run the wipers and switched the ignition OFF when they got to the normal parked position, but keep in mind the cycle wasn't finished yet. Then by looking at the position of the linkage arm, I realized that with a short spanner, I would be able to get the nut out, because it looked like this:
So I got myself this bad boy and managed to remove the nut and the washer. Lifted off the linkage, turned the ignition ON and let the motor finish its cycle, and then re-fitted the arm and tightened the nut.
Now the wipers park exactly where they should and all the modes work just perfect, including the intermittent. As a final touch, you could stop the wipers in the vertical position again, just to get good clearance and tighten that nut properly with a ratchet/spanner this time.
Oh yeah, re-fit the air vent...
Can't describe how pleased I was with myself after doing all this :D Such a small thing, but makes a world of difference in the rain, considering the fact that I drove 2+ years with the intermittent mode problem.
Well, another E30 thing sorted :)
Have to give credit to this guide that I used myself > http://www.e30zone.net/e30zonewiki/inde ... per_faults
The next job I'm planning to do is to sort out the rust on the sill panels, where I will also be putting new metal brackets that connect the sills with the subframe bolts. Got some new parts from BMW, so will post an update with pictures soon.
Thanks for all your help guys :)
appletree
Sun Jan 11, 2015 9:58 pm
Wow very detailed write up there!
zd3bx
Sun Feb 08, 2015 5:00 pm
No mega news lately...
Someone slightly scraped the driver's side wing and moulding last week while I was parked, which also clipped the side indicator as well...
Anyway, long story short, refitted the wing moulding properly, but decided to replace the amber indicators with clear ones, because the driver's one was in pretty poor condition inside (the metal clip heavily rusted, thus not holding), so I thought I'd use the opportunity to "upgrade"...
The result:
The indicators are made by Depo, came in a TYC box. I swapped their rubbish gaskets with my current BMW ones and also had to cut the bulb holders slightly, as they were too long and the light flashing wasn't visible enough. Good thing, they came with orange bulbs in the box.
And here are the parts that I bought getting ready for the sill panel repairs:
The brackets for both sides with the "shields" and bolts, plus the subframe bolts with new washers and nuts.
A bit busy now with a few other things, but when the time's right, the sills are getting sorted next :)
jimbom30cab
Tech 1 freak
Sun Feb 08, 2015 5:21 pm
Great work there and love the new bits going on
Sun Feb 08, 2015 6:02 pm
Good to see someone buying all new hardware for the rear axle bushes. The bolts are not the correct type though.
zd3bx
Sun Feb 08, 2015 7:40 pm
bss325i wrote:Good to see someone buying all new hardware for the rear axle bushes. The bolts are not the correct type though.
I got the part number from RealOEM and also checked it against my VIN on BM Mini Parts, which is: 51 71 81 81 460
That should be the correct part number, unless they've changed the bolts recently and they look different from the original ones.
By the way Barry, PM me if you do bodywork in your place and if fixing the rust on my sills is something that you would be able to do. Can take pics to show the extent of rust, etc.
Sun Feb 08, 2015 10:02 pm
No the studs, (no 2 in the link you pm'd) are correct but the silver colour bolts in the bottom left of your pic are wrong.
The four bolts either side that screw into the plates are number 6 in the diagram and should be black and with and integral washer.
I ordered four last week so they have not changed.
Will pm regards bodywork.
Marneus
Mon Feb 09, 2015 5:04 pm
Hi,
The clips that you used for the windscreen washer pipes, where did you get them from as mine have are leaking in the same place as yours was.
Jamie
Automaton
Tue Feb 24, 2015 10:42 am
Great thread and love the detailed write up and pictures.
Helped me figure what this is for:
https://farm8.staticflickr.com/7503/160 ... 0496_c.jpg
I got a bag of plastic trim back from the workshop and among others was trying to figure where this one went :)
Maneesh
1986 E30 M10 316 Manual Schwarz Chromie
1982 E28 M20 520i Henna Rot - Project
1988 E32 M70 750iL Schwarz - MASSIVE Project
1991 W201 190e Automatic Schwarz - Sold
1991 W201 190e Automatic Silver AMG Tribute - Sold
1993 E36 M40 316i Manual Brillantrot (RIP: rotting in peace)
Join other Carb Fanatics: E30 316 Carb - The Faithfuls https://www.facebook.com/groups/444263742439145/
Tue Feb 24, 2015 12:55 pm
Automaton wrote:Great thread and love the detailed write up and pictures.
Its a shield that fits next to the wiper motor
Automaton
Tue Feb 24, 2015 1:00 pm
Thanks! :cool:
Maneesh
zd3bx
Sat Mar 28, 2015 5:26 pm
Nothing too exciting so far, as I'm still looking for a bodyshop around London to get the sill panels replaced/repaired. Got recommended one place in Barking (Just E30z), but still haven't had the time to go there and get a quote.....Need to get these sills sorted asap, before I move onto the rear suspension bits.
In the meantime, I've changed oil + filter today. Haven't put a lot of mileage since the last change in January 2014 (approximately 5k), but it only costs 20-30 quid to change oil, so why not? The old oil was dirty black anyway...
When I bought the car in 2012 and did the first service (plugs, all filters, etc), I used Shell Helix HX7 for the oil. Then last year I went for Mobil Super 2000 X1, and now I decided to try Castrol Magnatec. All 10w40 grade.
Can hardly tell any difference to be honest...Price-wise, Shell and Mobil are pretty much the same, but Castrol is a bit more expensive and also it doesn't come in a 5 Ltr container, so I have to buy 4+1.
That's it for now. Will give you an update once I know what I'm going to do with the sills.
zd3bx
Mon Jun 22, 2015 8:30 pm
Parked the car up the other day and after doing my "regular visual check" to make sure everything was ok with the car, noticed the rear box was hanging too low...
So I thought what could be wrong, because it was just 2 years ago that I replaced the metal brackets for the rear box along with rubber mounts, so it was all new there.
Had a closer look and it turned out those rubbish Febi rubber mounts cracked and split apart on both sides and the box was barely held in place by that middle supporting mount, which was heavily stretched. See pics:
This was the only thing holding the exhaust at the back:
This time I decided not to mess around and just ordered genuine BMW bits which were priced quite decent, to be honest, plus they were in stock. The whole set cost me around £20...
You'll need 2x of the fat mounts for the rear box - 18 21 1 712 838
And 1x that sits further down towards the front of the car - 18 21 1 105 635
Hopefully the prop's guibo disc and the center bearing, which are also Febi, will last much longer, otherwise I'll completely lose my faith in Febi brand. However, one thing I noticed is that Febi exhaust mounts were quite a lot thicker and harder, so I really struggled fitting them, but BMW ones were quite flexible and soft, so mounted quite easily. Anyway, lesson learned.
No news with replacing the sill panels yet...Unfortunately, it's not a mechanical "bolt off, bolt on" job, so it's more complicated to find a decent place to do it and for the right price.
zd3bx
Sun Aug 30, 2015 10:48 am
I now finally have everything that I need to repair/replace the sills - it's just a matter of doing it :)
Obviously, the main thing are the actual sills...Still available from BMW and they are about 50 quid each - surprisingly decent price. The part numbers are:
Left side: 41 35 1 936 505
Right side: 41 35 1 936 506
I also bought all the fittings for the SE skirts, as I've got a feeling once we take them off, the clips won't be re-usable due to their age/condition...
The whole set cost me less than £30, which isn't too bad I guess.
And I ordered the correct bolts for the subframe-to-sill brackets, as Barry mentioned earlier...Just over £20 for a set 4, they better last long.
That's it. Hopefully will get the car into the workshop next month and get it all done. I'm not 100% sure of how we are going to do it, possibly we'll replace the sills partially to safe the hassle of stripping a lot of things, but we'll see how it goes.
Will try to take a few snaps, if possible. Thanks for following.
Mitchen
Sun Aug 30, 2015 11:42 pm
Great stuff! 8)
1990 320i Coupe SE
TPS
Mon Aug 31, 2015 8:58 am
Great Thread, Subscribed
