318iSh..... Banded steels & Lows
oldroydsr4
Thu Dec 30, 2010 5:19 pm
lee wrote:prob get 10mm in i'd of thought...depending on mounts...look to see what threads poking out the bottom, or undo the night until its just got full thread poking through the nut and measure the gap! neither of mine hit the underside of bonnet....
I have 13mm spacers on my mounts and there is still plenty of room between the engine and bonnet.
I didn't want to go any higher than this due to the prop angle.
Make sure you consider coolant hoses and pas lines as you lift the engine to install the spacers, I managed to pull the hose of the Pas reservoir and ended up with alot of fluid on the floor.
VWinston
Tue Jan 18, 2011 4:11 pm
Some great info there guys :)
Anyone got a sump?
I repaired the sump with quicksteel and filled it up with oil, went for a quick drive and its as good as new.. but on leaving the unit I cought the sump and knocked off the quick steel repair lol so I need a new sump so I can get this car sold.. Or i will be forced to break it for spares :o:
Palmer8
Fri Jan 21, 2011 5:47 pm
i replied to your for sale thread on edition and sent you and e-mail could you reply please :D
steviebmw
Fri Jan 21, 2011 7:49 pm
sorry what was it you emailed
AlpineAde
Sun Jan 23, 2011 5:15 am
Palmer is replying to Winston I suspect, Stevie.
Paulbadboy
Sat Feb 12, 2011 4:47 pm
Would yur mate make me a set of rims ....?.
