Hartge H36 Project (E30 M3 with S38 M5 engine)
Tue Nov 30, 2010 12:40 pm
i'd say its a common sense upgradings. but i don't have £50 to my name let alone to buy the car.
Jon_Bmw
Dangerous when thinking
Tue Nov 30, 2010 12:43 pm
Me neither, thats why I don't know. :cry:
This is potentially a £20-40k car I guess. It might be worth investigating a bit further, because if you could get up to the top end of the scale it is probably worth it.
Theo
Tue Nov 30, 2010 12:50 pm
Jon, my view is that these modifications are rather insignificant compared to the whole re-shell issue. I have no idea why Hartge didn't use the M5 servo and master cylinder in the first place - it's a bolt on upgrade with no hassle.
There are other changes I've made from the original - the 8k tacho with integrated oil temp gauge rather than a 7k tacho with the econometer gauge thingy sprayed black! I'm fitting a standard 325i overhead check control panel with oil level warning light. Hartge went to the trouble of fitting an oil level sensor to the bespoke sump, but didn't change the original M3 check control panel (which has no light for oil level) to a standard 6 pot version (which does)!? I've reduced the size of the airbox so that I don't have to chop aload of drives side chassis rail away. I've relocated the oil temp sensor from the sump to the oil filter housing to give a more accurate oil temp reading.
Tue Nov 30, 2010 1:07 pm
Modifications like this only increase the value IMO, anyone that thinks otherwise should stick to their iS :)
anothere21323i
Tue Nov 30, 2010 6:43 pm
Theo, just out of curiosity, what did you do with the suspension and wheels from the donor shell?
Theo
Tue Nov 30, 2010 7:00 pm
I sold them. :)
anothere21323i
Tue Nov 30, 2010 7:45 pm
D'oh! I was really hoping you were going to say something along the lines of 'they're in the loft, lovingly stored and waiting for a zoner to come along at the right time with a wad of cash to entice me with'..... :D
Tue Nov 30, 2010 8:00 pm
Theo its never going to get done, sell it to me please :D
Theo
Tue Nov 30, 2010 8:07 pm
Steve, you have more than enough scrap to contend with. I wouldn't want to burden you with more.
Tue Nov 30, 2010 9:20 pm
Theo325 wrote:Steve, you have more than enough scrap to contend with. I wouldn't want to burden you with more.
you can never have enough scrap Theo, :D
Dave_M3
Wed Dec 01, 2010 12:58 am
Indeed more pics are needed even if its just of amassed parts :D
The other advantage of the dogleg is that if you end up deciding the S38 is a disappointment you can always get a 525e bell-housing and stick in a mighty M42 instead :lol:
Theo
Sun Dec 19, 2010 8:18 pm
Just spent A LOT of Euros on an original Hartge H35/H35-24 sump - I will not be buying Xmas presents for anyone this year! I figured it was probably the only chance I'll ever get to buy a good one to replace my twice repaired version.
Sun Dec 19, 2010 8:23 pm
did it hurt? go on how much?
Theo
Sun Dec 19, 2010 8:33 pm
How much did your new set of headlights for the C2 cost? I'll say whether it's higher or lower. :)
Sun Dec 19, 2010 8:40 pm
about £350 a side i think. :o
Theo
Sun Dec 19, 2010 8:42 pm
:eek:
Sump cost me £570 inc delivery. Think the previous owner paid double that to get it repaired so in that sense, it's a bargain.
Sun Dec 19, 2010 8:48 pm
it will look good when the cars up on a ramp! hartgay sprouting from the sump at you
gaiter arrived v.nice it is too.
Theo
Sun Dec 19, 2010 8:55 pm
Sadly the lovely Hartgeee emblem will be concealed by this gnarly lump of Kevlar.
Fortunately, that has a Hartge symbol too!
Glad that you're happy with the gay-tor!
Dave_M3
Sun Dec 19, 2010 9:19 pm
That sump is sweet all the same even if it did cost as much as some E30s :eek:
The sump guard is even more impressive though! Where did you pick that up?
Theo
Sun Dec 19, 2010 10:10 pm
I got the sump guard off ebay.de last year some time, thought it would be a worthwhile investment given the past history of the sump. I'm certainly glad I have it protecting this new sump!
Dave_M3
Mon Dec 20, 2010 1:59 am
Was it expensive... if you don't mind me asking?
And what weight is it?
Theo
Mon Dec 20, 2010 9:51 am
No it wasn't too expensive - I think I paid about £120 for it. It's not particularly heavy, about 5/6kg? I've never seen another one for sale though, so you might struggle to source one.
Mon Dec 20, 2010 9:58 am
Nice purchase Theo ! :D
may have been expensive but it had to be done , what's the chances of another turning up ? :eek:
with a sump that expensive and rare I would be fitting Range rover suspension... 2 foot ride height FTW! :wink:
Theo
Mon Dec 20, 2010 10:33 am
Thanks Steve, I've run the figures through my man maths calculator and it turns out it was actually a bargain.. Phew.
It will be interesting to see what ground clearance is like on this car with the sump guard fitted. Very little is my guess.
Here's an old pic of the car prior to it's interface with a lamp post or whatever it was.
staley_turbo
Mon Dec 20, 2010 11:15 am
How have i only just seen this! :eek: Amazing job, now watching.
Theo
Mon Dec 20, 2010 12:09 pm
Thanks, it's a slow moving project as you can tell. It's been going for 2 years now.. :(
I WILL have this car done in 2011.
Hopefully.
gareth
Wed Dec 22, 2010 11:35 pm
Top morsel sourcing there! :)
You should see the state of my sump after scotland last year 8O Thankfully it's only worth about the same as the oil inside :P
racing_snake
Mon Dec 27, 2010 12:40 pm
wow!!! this is what its all about!
it may be a long time project but you will be glad you took your time when she is complete and ready to issue slaps at your command!
No Half Measures...
Tue Dec 28, 2010 8:55 am
It had to be done theo. what did the sump retail at if or when it was available?
tha881
Sat Jan 01, 2011 6:44 pm
U said your next update on this project would be in 2011 !!!
Maybe im a tad impatient, but this is one the best restorations i've seen
Best of luck finishing it this year
Theo
Sat Jan 01, 2011 9:53 pm
Haha, thanks!
The new sump has arrived and the plan is to fit that to the engine block, fit the bell housing from the gearbox, lower that into the engine bay and bolt it to the subframe, fit the gearbox and bolt it up to the car. Then I can weld on brackets to the chassis rails for the sump guard and check I'll also bolt the head to the block with an old gasket, fit exhaust manifold and check for clearance issues.
Theo
Fri Jan 14, 2011 9:13 pm
Fitted the engine to the shell for the first time which is kind of cool. Only a trial fit as described in my previous post but it at least gives something approaching a sense of progress.
Plan is to trial fit all the parts which may give clearance issues but before that I need to get the engine position right, I don't think the e34 m5 engine mounts are ideal - the offside of the engine needs raising about 10mm. The engine is also too far back at the moment and I can't bolt the cam carrier to the cylinder head due to the bulkhead getting in the way. No biggy, as the viscous fan is still about 20-25mm away from the radiator. I'm thinking of doing away with the viscous fan altogether and relying on the electric fan, like a standard M3 does. Might need to use some water wetter type additive which lowers coolant temperature as cooling the S38 in an e30 shell is a bit marginal.
The exhaust manifold downpipe for cylinders 4/5/6 seems to be clashing with the underside of the car, so some tweaking is needed there.
Will try and get some pics up tomorrow.
staley_turbo
Fri Jan 14, 2011 10:02 pm
Slap me for being stupid, but i thought this engine was factory fitted to this car? So there shouldn't be any clearance issues?
Kedge
Fri Jan 14, 2011 10:30 pm
Factory fitted by Mr Hartge and a big hammer to the transmission tunnel. Theo is using a different shell though as far as i remember because the original was smashed so needs to carryout similar work to the shell.
Instagram - Kedge85
Jon_Bmw
Fri Jan 14, 2011 11:32 pm
Kedge wrote:Factory fitted by Mr Hartge and a big hammer to the transmission tunnel. Theo is using a different shell though as far as i remember because the original was smashed so needs to carryout similar work to the shell.
With a smaller hammer?!? :)
