Cleaned up as well as I could do them:
Zinc plated
And passivated
I'll have to start saving soRav335uk wrote:Very nice Brendan.
Oh, and those bits for the interior are now in the process of being made for you.
That should be sufficient enough, Por 15 is only good if you have a good key for it to bond too, Hence grit/sand blasted, Otherwise its shit stuff that peels off easy. If i was doing it again i would not use por 15.Jozi wrote:They probably do but I'd like it done this weekend. There's etch primer, zinc primer and nearly 2x coats of black on the diff, it should be enough until I get the diff rebuilt.
Yeah, I have no idea tbh! I was going to go with it being as normal as possible but I want sensible tires on this and might need a little camber to make sure nothing fouls on anything.appletree wrote:Is you rear beam adjustable? What are you setting the toe and caster to?
I kinda realised that as well after I got it all bolted upKedge wrote:Serious peado levels going on here Brendan, impressive work!
