"council'd" my cabby
320iAN
Wed Mar 05, 2008 7:21 pm
cheer's Blitz .. i quite like that look to :? .. decision's, decision's :mad:
toby
Thu Mar 06, 2008 8:45 am
320iAN wrote:
toby wrote:is the center bore the same size too?
how does the colt feel on bbs?
the centre bore was slightly bigger on the BBS than what the Colt need's .. not by much though, i didn't have to fiddle about fitting the BBS as the colt has stud's so they held the wheel while i put the bolt's on winkeye
as for the feeling while driving .. i couldn't tell you? all i did was fit them, made sure they cleard everything and handed the key's back to my wife :D
Well are you sure that's ok?
I asked some wheel specialists when trying to fitt bbs to my toyota and although the studs hold the wheel ok - they said it would be preferable to run with spigot rings to take up the difference. Otherwise the wheels may wobble at speed if they are not perfectly central on the wheel.
320iAN
Thu Mar 06, 2008 9:27 am
i had the Colt out yesterday and took it along a private test track winkeye
there's not a bit of judder from the wee colt with them fitted so i'd say there's no need for spiggot's, this time?
