Russ' E30 M52 moneypit
russ325i
Mon Jul 28, 2014 12:14 pm
Jozi wrote:Thanks Russ, i meant to reply or maybe i did, crappy internet at work.
I had hoped it was finished by now, never wanted it to go on for 3+ years, it got slightly out of handy if im honest.
No point putting it of if theres rust there it will get worse but im sure you know this already
Exactly, and they go from the inside out - I've just been putting it off until she's running again so as of this weekend I'm running out of excuses! I've only got a few more smaller jobs to sort out and then I'll get the interior all out and hang the carpet up to dry. When I recently put her back up in the air on stands again a bit of water came out of the wheel well so despite having been garaged for years there's definitely some in there. I'm just praying it isn't too bad.
ross_jsy wrote:Hey Russ did you go with the single mass flywheel in the end? If so do you have the old dual mass knocking around? Need to lock my crank to undo the crank bolt and m20 fly's don't have the provision for a locking stud
I threw the dual mass one back in as we deduced that the play was probably still within tolerances so figured it'd do for now and save me £300. It wasn't juddering in when I drove the donor car so hopefully it'll be all good. Sorry I can't help you with that one mate!
russ325i
Mon Jul 28, 2014 12:54 pm
M52SWAP QUESTION! What throttle cables have people used? Either the local stealers have provided me with the wrong one or I'm a clown and ordered the wrong one. It's a good seven inches too short after the bend. Any suggestions would be greatly appreciated!
SO, I recently bagged a pair of Evo arms with new metal balljoints already pressed in so they should be in the post all being well, which is nice. That'll help with the wheel positioning in the wing due to the use of E36 struts that I completely hadn't considered until fitting the brand new E30 ones I bought. Yet another incorrectly ordered part, that's 4 so far (gigantic brake servo, crimp-on Euroquip fittings, non-Evo arms, throttle cable). Mistakenly ordering parts is fast becoming an expensive and wholly unfulfilling hobby of mine.
Tris was right about the EWS - you only need the live feed to the accessory part of the ignition barrel, an earth and the green wire into the E36 loom. Nothing else. Knowing this can only mean one thing: she fired up and didn't even catch fire. Result.
The cables have now all been tidied and shoehorned into the less than generously sized E30 cable box on the bulkhead and it's all secured thanks for a few cable ties (which doesn't look quite as naff as expected believe it or not). I'd have taken some photos if my phone battery hadn't have died and my girlfriend hadn't taken my camera on holiday with her (leaving me a free weekend to play with the car and less earache about spending my hard-earned on holidays when I want to finish the car, what a keeper). Anyway, she's starting to look like an E30 again now with the rad plumbed in and front end re-attached:
As per Zone engine swap rules, here is a short video of the first start without an exhaust fitted:
http://vid1373.photobucket.com/albums/a ... 884a0d.mp4
Just the brake servo and plumbing, massaging of PAS pipes, sourcing and fitting an electric fan, 5 stud conversion for the back, exhaust, make up a prop and build up the diff then she'll be done.
But first I have to remove the carpet, hang it out to dry for a week (probably), remedy any rust on the inside and relocate the battery to the boot whilst I'm at it. Hopefully within a month she'll be moving under her own steam. He says.
ross_jsy
Mon Jul 28, 2014 1:42 pm
Bought my cable from Jackson's. Might have the invoice with a part number on at home. Iirc it's from an e34 with m50
russ325i
Mon Jul 28, 2014 4:32 pm
ross_jsy wrote:Bought my cable from Jackson's. Might have the invoice with a part number on at home. Iirc it's from an e34 with m50
If you could check when you get the chance that'd be massively appreciated mate - I too bought mine from Jacksons and it was from an E34 525i with an M50, which is weird.
Does yours route between the head and the bulkhead? Mine's a little lower over the top of the bellhousing as there's no space further up but there just isn't enough length after the cable assembly itself turns 90 degrees (metal bend) there just isn't enough cable after that to make it to the throttle body.
ross_jsy
Mon Jul 28, 2014 8:08 pm
Right this is the PN on the cable:
35411160611
Real OEM lists it as for:
E34: Details on E34
E34 520i Sedan, Europe
E34 520i Touring, Europe
E34 525i Sedan, Europe
E34 525i Touring, Europe
E34 525ix Sedan, Europe
E34 525ix Touring, Europe
Mine went in-between the head and the bulkhead. IIRC there are clips on the bulkhead cover to secure it in place
russ325i
Mon Jul 28, 2014 8:43 pm
Cheers for that Ross.
Strangely, I've used part number 35411160609 which comes up on RealOEM as listing pretty much the same vehicles as your one ending in 11. Same same but different part number.
Comparing the RealOEM slides side by side they seem to be showing the same diagram. I reckon it's because I haven't squeezed mine behind the head which is a bit crap because now I've secured all the wiring it's going to be a ballache to get it through any further up. I'll give moving it upward a go unless anyone else spots a glaring difference between the two cables!
ross_jsy
Mon Jul 28, 2014 9:11 pm
There is a shorter cable and a longer cable. I can't remember why (possibly for traction control or cruise control equipped cars) but it's the longer one that is needed. I can measure mine for you tomorrow if you want?
KIRIEIW
Zone Newbie
Tue Jul 29, 2014 5:55 am
Nice project! Can't wait to see pics of it done :D
russ325i
Wed Jul 30, 2014 12:35 pm
ross_jsy wrote:There is a shorter cable and a longer cable. I can't remember why (possibly for traction control or cruise control equipped cars) but it's the longer one that is needed. I can measure mine for you tomorrow if you want?
If you could mate that'd be spot on - just in case I end up ordering a different one and it's even shorter! It might be the way mine's been routed, if yours is the same length I'll just slacken off the gearbox mounts, stick a jack underneath the 'box and re-route the cable behind the head. Hopefully! Cheers for that.
KIRIEIW wrote:Nice project! Can't wait to see pics of it done :D
Thanks! It'll be a little while before I get around to having her resprayed but if I can end up with a tidy, usable E30 that goes fairly well and handles properly by the end of September in time for our last trackday of 2014 I'll be pretty happy.
russ325i
Thu Aug 07, 2014 11:49 pm
Managed to get a few hours of work on the E30 in this evening so the NOS offside bumper bracket was bolted up to allow the front bumper to go back on, the gear linkage and Z3M short shift are fitted (cheers Tris for the massive patience bending the selector rod time after time so that the shifter sits nice and centralised - I would have just dealt with it and then whinged like a little girl in a few months when I inevitably wouldn't be arsed to take everything back off underneath to rectify things) and my Clio servo (take 2... I mean phase2) has been sanded down, treated for rust (nice of the breaker not to bother wiping the brake fluid from all over it before sticking it on the shelf) primed, painted, lacquered and fitted. Those studs aren't exactly generously proportioned but once you get the bottoms nipped up it all goes on nicely. Ooh err. There's an absolute shitload of space between the inlet fannymould and the servo too, which is a relief. I didn't even have to grind off any of the inlet manifold fins. Nice one Nicole!
I'm hoping to get the prop and LSD sorted over the weekend as well as fit the Evo wishbones I've managed to source (if they arrive tomorrow) which'll enable the wings to go back on too. When I say back on, I just mean on really because they've never been on before as the old ones were shafted so it'll look a bit like a subtle take on a Golf Harlequin. The yoof are going to love it, innit.
Upgraded exhaust system and 325i downpipes ordered so we can start butchering / fabricating something that works shortly, as well as Powerflex Black Series goodness for the front ARB paired up with Lemforder Mondeo drop links and new rear wheel bearings so it's pretty much just the rear hubs, coilovers and a throttle cable that isn't five lightyears too short to find funds for / get around to ordering now and I think that'll be job done.
There's a trackday on the 12th September which would be ideal for getting it all dialled in properly. I'm not feeling particularly optimistic.
Tired now. Shedloads of pictures:
M3smudge
Fri Aug 08, 2014 8:25 am
Coming along very nicey. Well done
ross_jsy
Tue Aug 19, 2014 9:14 am
Completely forgot about measuring that cable. I'll do it tonight
Tue Aug 19, 2014 9:34 am
Would have been nice to see that renault sticker removed, rather than masked up :D
russ325i
Thu Aug 21, 2014 8:25 am
DanThe wrote:Would have been nice to see that renault sticker removed, rather than masked up :D
Balls, I was hoping that the Bosch part might go some way to outweighing the French wrongness Dan... Ha! :roll:
russ325i
Thu Aug 21, 2014 8:43 am
Because I've been so busy at work / spineless and have run out of subtle ways to steer the conversation every time anyone mentions lifting the carpet to check out the floorpan carnage before our eyes when it gets lifted for the first time in 20 odd years Tris went ahead and did it on my behalf without warning and sent me some photos.
For all of you iron oxide fetishists out there it's time to get ready for the money shot, although I'll have to disappoint you because as much as she's soaking wet it's more like just a bit of dry humping rather than a full-on, triple x-rated mess all over her stomach kind of photo shoot:
So basically I feel like possibly the luckiest E30 owning bastard alive right now. Let's see how long that lasts.
'Buy the biggest fan you can fit in there', he said. Rather than measure the actual area where the fan would go I decided I'd be clever and use a combination of Google, RealOEM, the Mishimoto website (for futureproofing) and some forums to decide that I'd fit a 16" fan on my rad. So sliding my gigantic new fan into its future home was fairly interesting. The good news though, is that it is quite literally the biggest fan I could have managed to fit in there:
Controller all fitted and wired too, ready to go:
A bit of Powerflex goodness whilst I wait for ECP to deliver the 'in stock' wheel bearings that have been on back order for about a week so that we can press the Z3 hubs into the trailing arms and re-fit it all and finally get around to swapping the rear brakes from the donor car onto the E30.
We also fitted the new throttle cable and I'm pretty happy to announce that it now all works as it should.
Everything required to get her on the deck and driving bar the coilovers has been ordered now (I think) so I'm just off to buy some scratch cards then I'll be making a call to BC Racing...
russ325i
Sun Sep 07, 2014 9:49 pm
So, as it's been a good couple of months since we moved the E30 out of my garage to try and get on with things it's been noted that I should really pull my finger out. We realised that there was no way it'd be ready for the trackday coming up this week but had to make space for Tris' M3 to be tinkered with in the run up to the aforementioned trackday. Game on.
I'm going to say it with pictures because I'm knackered.
Pressed Z3 hub and bearings into my trailing arms and assembled the rear end:
Realised that I'd forgotten the backing plates, threw a few choice words out there and then undid all of that work ready to do it all again later. Secured the replacement boot on my decidedly secondhand M3 Evo arms before I forgot (then trimmed the lockwire a bit after taking the photo, of course):
Tris built my LSD up in the meantime. Judging by the amount of swearing and loud exhalation I gather that he doesn't particularly enjoy it, but he's good at it and has all of the kit to measure the backlash and whatnot so unfortunately he managed to get lumbered with it. It didn't help that it was about 80 degrees centigrade in the sun and the press was outside, in the sun:
This would be a demoralising scene but thankfully two of the visitors to the shed didn't own the cars they rocked up in. My haggard looking (but very solid) E30 didn't really compare:
This actually was a demoralising scene. MYTH: using Z3 2.8 hubs will allow you to bolt any non-M rear discs and calipers onto your rear-end set up. That'll be a pair of Z3 discs and calipers I'll be needing to source then as no amount of trying to hybridise the E30 carrier with the E36 caliper to get the fixing points to align and/or machining a spacer was going to work if I wanted a fully functioning handbrake. Which I do. Here's the proof:
Diff built, rear-end pieced back together for about the sixth time and in place ready to lift up using the 328i discs just for now to get her rolled out of the shed:
Another one of those what the actual f*** moments where you can't realise why it's decked on one side but fine on the other:
Cue letting air out of the tyre to avoid shredding it or annihilating the arch before planning on cracking out the arch roller. Bent the tyre valve in the process trying to speed things up. Oops. Then the sudden realisation that the other rear spring was still on the floor outside, that'll be why then...
Called it a night. Got drunk.
A new day, new problems. Checked the speedo sensor compatibility from small to medium case, RealOEM confirmed they're the same so I swapped them over. Result. Had another issue that made me have a minor meltdown but more on that later. Back on the deck and ready to roll outside before realising that I hadn't put the steering linkage back on properly. I guess it's just one of those weekends. Put it all on properly, calmed down a bit.
Ignoring the odd ride height I'd say the wheels don't look as offensive as I'd thought they might do as I'm not a fan of anything bigger than a 16 on an E30. Unless something else turns up soon I'll most likely refurb these in the new year and get some slightly lower profile rubber once I kill these ones. Offset seems pretty decent too which is probably more luck than anything else, especially as the Z3 hubs seem to have added between 20mm and 30mm to the rear track.
As the body work is in desperate need of some new paint I turned my attention to what's left of the donor car to make myself feel better. Must get the last few morsels off of that soon and get it cubed:
PROPSHAFT NIGHTMARES
The front section of my 328i prop is too bulbous and fouls the bottom of the gear linkage (fitted with a Z3 short shift). The linkage has been bent to get the shifter aligned absolutely spot on up top and from previous experience of this set up on my E36 I don't want to change it as it provides a really bloody good shift feel. Has anybody else experienced this issue using the same combination of parts or am I just unlucky?
About 3mm would probably do it so we considered spacing the gearbox mounts and centre bearing but it's a little on the pikey side. I had a 323i prop squirrelled away and it looked good width wise despite being ever so slightly longer so we cracked out the verniers and it's 5mm skinnier. Bonus! The only thing is that the bolt pattern onto the prop donut is different (Getrag box versus ZF box I guess?) but what nobody thought of at the time was whether the 323i donut could be swapped with the 328i one still attached to the gearbox. I'm hoping this is the case, but does anybody know off-hand by any chance if that'd be viable? Any help much appreciated as I'm taking a week off of cars to chill my boots and concentrate on the house.
Jobs left:
Order parts for and fabricate remote reservoir
Make and run braided brake lines for the front
Source Z3 calipers, carriers (second hand) and discs (new, all hail ECP)
Tidy up wiring under dash
Cut speaker panel on driver's side to accommodate new power cables
Secure battery that's now in the boot
Fit exhaust system and modify manifolds / downpipes to suit
Wrap exhaust manifolds in cheap heat wrap that will probably disintegrate within minutes
Make adapter and fabricate mount for the air filter
Order and fit coilovers, cry at my ever increasing mountain of debt
Dremel the injector rail cover down to fit nicely at the back and re-fit
Oil breather return re-routed
PAS pipes made and connected
Top-up / fill all fluids
Spanner check EVERYTHING
Test drive, see what falls off
Put whatever falls off back on
Test wind-down windscreen
Fix niggly things for the rest of eternity whilst being scared to let the bodywork come into contact with any water at any time
russ325i
Sun Oct 12, 2014 5:43 pm
One month on and it's finally on the road. There are still a few things that need tinkering as can be expected but it's nice to be driving again, especially now it's slashing it down with rain. Well, I say that, but the 'Horace Horizon' tyres on the rear are absolutely lethal in the wet. Thankfully, I've agreed to 'look after' a staggered set of E36 M3 Sunflowers and pay for them sometime next year which should help a bit as they've got T1Rs on them.
Here's a quick rundown of the last month with a shedload of photos:
Thanks to a set of overpriced and nicely rusted Z3 caliper carriers that thankfully didn't scrub up too badly from a breaker who really, really didn't give two shits about customer service I managed to get the E36 rear calipers bolted up to those absurdly deep Z3 discs.
Treated myself to a new knob from the stealer, £43 for the weighted version isn't too bad considering a bog-standard non-M one goes for about £22 plus P&P second hand:
A new diff gasket came down as part of the same order, so I instantly regretted not thinking of that earlier (before the diff was back in the car):
Work on the manifold and downpipes began:
Then continued, with the addition of a boss on the front bank for the O2 sensor:
Itchy arms galore after wrapping them up:
Aaaaand, easy as that. Except with a load of swearing and more than my fair share of spanner rash:
Gigantic replacement PAS hose. I asked the chap to make it 140mm longer but he didn't seem like a metric kind of guy and said he'd make sure it was long enough. He's certainly a man of his word:
Finally got rid of the donor after removing almost every last little morsel. Good riddance, thankfully Tris has a very understanding wife although I had the feeling that I was pushing my luck a bit so it was definitely time to tidy up around theirs:
Shiny bits courtesy of BC Racing. There are tried and tested with my lot on two (soon to be three) different M3 Evo dedicated track cars and they're bang on for the money and seem to be standing the test of time too so I figured I couldn't go too far wrong. E36 front struts with E30 camber adjustable top mounts and E30 non-coilover rears:
Obligatory 'arch rolling workout. The rears are rolled / folded but not flared a great deal as the wheel offset is just right, the fronts look meaner flared so I might even go back for more in the future but this is enough for now without destroying the paintwork:
Otto in all of his multicolour glory waiting to come home:
And back home in my somewhat more compact organised chaos of a garage at long last (4 months, maybe?), albeit with the indicator plugged into the sidelights and the fogs plugged into the indicator, which is, er, different. I'm going to swap that back over in a bit after a cuppa:
Not the best of weather to be playing cars but I'm just waiting for some longer wheel bolts to arrive for a 10 minute test to see if 15mm spacers help with my wheel clearance issues. I'm not feeling amazingly hopeful, but the steering lock is currently abysmal and that's with E36 Evo arms too. It looks like it might be a borderline prohibitively expensive set of mega-lock arms to add caster and a bit of track too. The extra lock will no doubt be handy when it's raining on track too so that I can have a little play with my wind-down windscreen. So, here's where I was at 20 mins ago:
RustyRuss
Sun Oct 12, 2014 5:55 pm
This is a stonking thread and build Russ - well done, keep up the great work :-)
Russell A Macfarlane
Central Scotland
russ325i
Sun Oct 12, 2014 6:35 pm
Thanks Russ, she's certainly nowhere near as clean as the one you've just picked up but there's plenty to keep me busy over winter. I'm going to get her up in the air to clean and re-underseal the wheelarches this coming week in the hope that my paranoia about getting the car wet abates slightly!
After that though I've still got enough jobs on the to-do list to last a lifetime and enough parts on the wishlist to warrant remortgaging my house, of course.
RustyRuss
Sun Oct 12, 2014 6:40 pm
Fantastic mate it sounds as though your well on top of things anyway!! Appreciate your comments on mine too thank you :-) I know what you mean I take huge steps to ensure any classic I've had doesent get wet...I'm like a bear with a grumpy face if they do haha!!
Central Scotland
davelarge
Sun Oct 12, 2014 7:00 pm
Good work mate! I've pm'd you for some info on the rear brake setup as I plan on going down the same route.
russ325i
Sun Oct 12, 2014 8:45 pm
If only there were more hours in the day Russ, then I could move from being organised to being productive!
Thanks Dave, I've replied with a bit of an essay but hopefully it's of some help. Just give me a shout if there's anything I've missed.
Cheers!
RustyRuss
Sun Oct 12, 2014 8:52 pm
Thoughts echoed there mate theres never enough time...due to that inconvenience we call work!!
Central Scotland
D4BOX
Sun Oct 12, 2014 9:13 pm
Very nice looking engine swap looks tidya˜‰
Jozi
Sun Oct 12, 2014 9:43 pm
Always look forward to reading this thread when I get a notification of a new reply!
Any tips on the exhaust wrapping? I have to do mine as well over the next few weeks when I get some time or it needs to be done.
russ325i
Sun Oct 12, 2014 10:55 pm
RustyRuss wrote:Thoughts echoed there mate theres never enough time...due to that inconvenience we call work!!
Yeah it's just a shame that the most inconvenient of inconveniences is the one that facilitates our hobbies!
D4BOX wrote:Very nice looking engine swap looks tidy
Cheers! I'm aiming to put enough aside to get it resprayed around March time so the outside should do the rest of it justice.
Jozi wrote:Always look forward to reading this thread when I get a notification of a new reply!
Thanks mate, I'll try and keep the updates coming whenever there's something new to see.
I soaked the whole reel of exhaust wrap in a bucket of water, went out to buy a couple of brake fittings (not an integral step in wrapping an exhaust of course, but to give you an idea of timings I'd say that equals about 25 mins of soaking time) and then cut off a metre or so at a time, starting at the rearmost of each manifold/bank wrapping it tightly and overlapping each previous loop about half way.
When you get to the end of each strip (extending past the where the tubes are welded and join the others) you want to wrap under and over both sides of the adjoining tube to ensure it stays tight. Make sure there are no gaps around this area at this stage. Then, you'll either need to be a jedi, have three arms, be very flexible or have a trusty assistant (I chose the latter) to put a finger on the end to stop it unravelling.
I had a load of those metal exhaust wrap ties and used just one of them before deciding they were crap and cracked out the lockwire pliers and a reel of lockwire, applying two separate loops of wire to both the start and finish points as well as an extra couple wherever it looked like it could go baggy. Securing the manifold in a vice is probably a good shout as it leaves you plenty of space to work and means you don't need extra limbs / telekinesis.
For the pipe at the front of each bank I used a longer strip and kept going all the way down the manifold and downpipe, overlapping the wrap on the other two tubes where you've been over and under previously, if that makes sense? I'm very aware that I'm knackered and trying to explain something using words rather than pictures. I should have taken more pictures.
Make sure you leave enough room around the O2 sensors to thread them in of course, or if they're already threaded in enough room to unthread them if they ever need replacing!
If memory serves it was a 20m roll 50mm in width and I had more than enough to get the job done.
The only thing left to do then is fit them up and run the engine up to temperature. I'd recommend doing this outside unless you want your shed/garage to turn into a sauna, and even if you do I'd recommend just getting an actual sauna because the soggy exhaust wrap stinks. There'll be loads of steam so you don't really want to be cruising down to the corner shop when they're still wet but at the same time leaving your steel exhaust cocooned in dripping wet (did I mention that it's a bit messy?) absorbent material probably isn't a great idea if you want it to last!
It's much easier than it looks, believe me, and with any luck should be functional too. I really wanted to fit the M52 airbox under the bonnet and am sure some people have managed it but it didn't take long to realise it wasn't going to be worth the hassle so I wanted to keep under bonnet temperatures as low as possible if there's going to be an open filter in there.
russ325i
Sun Oct 26, 2014 11:10 am
Small update, managed to get my hands on some E36 M3 Evo kingpins and hubs that have admittedly seen better days but considering they'd have cost £630 from BMW, suddenly £150 wasn't so bad. Thankfully, they've solved all of my steering issues so I'll get some genuine hubs and bearings in time as the kingpins are pretty hardy.
The heatshields were a bit gammy but I took a grinder to the tops to cut them down for cooling purposes (a mate of mine cracked the discs on his M3 Evo track car at Le Mans earlier in the year and as they were doggingly rusty I figured they should go). Didn't take a photo though because I was on a mission.
Wheel sitting pretty much as perfectly centred as possible, which couldn't make me happier if it tried. There are also M3 floating discs and calipers hiding under there which look pretty decent:
She's still looking a little rough around the edges but mechanically we're nearly there. Exhaust gasket on the way because ECP neglected to include one of them with my downpipes and no amount of Gun Gum has managed to fix the farting noise, still need to re-try fitting the short shifter, spend a bit of time on suspension setup and alignment, blah blah blah but at least I can go around corners properly now.
russ325i
Fri Feb 27, 2015 3:28 pm
So, a good few months on and I've managed to sort a good few things out but have mostly forgotten what they were so I thought I might as well put up a greatest hits in pictures.
By this evening I'm hoping to have refinished the missing grilles, swapped the dash for one without cracks, installed some speakers in the front and refitted most of the interior parts.
Heater control valve. Well that was fun. And cheap. I've also finally fitted a working temp sensor, catch can, degreased the ICV and PCV, fixed the exhaust leak, fabricated a heatshield / airbox as well as a battery tray in the boot (it started out as a 318iS), bought 10 revolutions as well as some track tyres and intermediates, sorted out the speed sensor and fixed the clocks amongst myriad other things. Oh, and resprayed the front end so it's all Sterling Silver now. It still needs a good machine polish but will do for now at least.
That just leaves an oil change, fitting the sump guard, swapping the water pump, getting it tracked, raising the rear slightly and rolling the rear arches to oblivion so that I can fit the new wheels and tyres under there, plumb in the brake bias valve (literally just need to connect it up) trying to stop the exhaust knocking against the rear valance because it does my head in and changing one of the boots on the wishbones as it's split and dropping in a bucket seat and harnesses before thrashing it around a couple of tracks in France at the beginning of April. Easy, yeah?
jimbom30cab
Tech 1 freak
Fri Feb 27, 2015 4:25 pm
Amazing work there. Is that a corsa c steering link?
russ325i
Fri Feb 27, 2015 5:40 pm
jimbom30cab wrote:Amazing work there. Is that a corsa c steering link?
Cheers! Well spotted, yes it is a Corsa C linkage - it only cost a fiver and is just about slim enough to miss the wrapped exhaust with a bit of room left to spare for engine movement.
The only ballache with it was the threaded part of the clamp on the lower half so I ended up drilling it out and using a nut and bolt to fasten and clamp it to the rack splines.
jimbom30cab
Tech 1 freak
Fri Feb 27, 2015 5:58 pm
Thought so, it is worth the mod though, rubber guibo delete and no manifold mods needed, double win!
russ325i
Sat Feb 28, 2015 10:22 am
Absolutely! And for only £5 it didn't break the bank either.
russ325i
Sun Mar 01, 2015 12:45 am
...and here's one with all of the Revolutions fitted after a decent arch rolling session this afternoon:
oomz1975
Sat Mar 14, 2015 10:52 pm
Great thread, nice work.
