BMW E30 325i Sport :-)
pony
Sun May 11, 2014 10:26 pm
£82 plus VAT
pony
Sun May 11, 2014 10:28 pm
bab-91 wrote::cool:
I didn't know you had a Tech 1, Pony.
Cheers mate yes had it for a few years now.
pony
Sun May 11, 2014 10:57 pm
Update
May 2014
I had to buy 2x New Lemforder Track Rods And also a steering wheel cover
These were bought from ECP.
These were fitted at KDS Wheel Alignment centre. The KDS wheel alignment was done on Hunter Hawkeye machine. I had to return a few hours later as my wheels needed balancing.
Basics about Wheel Alignment
KDS Wheel Alignment
Before And After
Sun May 11, 2014 10:59 pm
What's with the "Condom" on the gearknob :mad:
pony
Sun May 11, 2014 11:05 pm
To stop filthy mechanics dirtying the New Genuine BMW Illuminated Gearknob.
pony
Sun May 11, 2014 11:11 pm
Update
After the KDS Wheel Alignment and wheels balancing I was to join the BMW Car Club road trip.
I went to PacerPete's and he really saved my bacon and fixed a few outstanding issues
Speedo fixed: using used speedo cable
Sunroof: only works when a door is open and this was resolved by fitting a relay which was missing in the fuse box.
Test drive: drives and handles fine
Brakes: fine
Fuel leak: he investigated by looking near where the fuel pump is. There was a hole in one of the lines and he fixed by trimming this.
Tyre pressures were also double checked and inflated to correct tyre pressures.
Sun May 11, 2014 11:12 pm
Did Pete lick the steering wheel.. :D
Ha has a habit of doing this.
pony
Sun May 11, 2014 11:33 pm
Rav335uk wrote:Did Pete lick the steering wheel.. :D
No because my pus was all over it.
Just joking.
Sun May 11, 2014 11:36 pm
There's a pic of him doing just that on Blitz's car at Santa Pod 8O :mad:
Mon May 12, 2014 6:55 am
Being a tech 1 should this not have had a 3:64 diff not a 3:91?
pony
Mon May 12, 2014 7:29 am
B7 wrote:Being a tech 1 should this not have had a 3:64 diff not a 3:91?
Yes it should but being a London car I wanted 3.91 so is a little "nippier" at lower speeds
Gert_8
Mon May 12, 2014 8:12 am
Manufacturers ever considered that - fitting a diff depending on the part of the country you're living in?
Is this the car your planning to go drifting in?
Quaser
Mon May 12, 2014 9:02 am
Lots of work going on there - going BMW main dealer only would have cost you much more then you could have got the same parts for, but you probably know that already.
Did you do any of the work yourself or was it all outsourced??
(£65 to replace a boot seal - come on - thats not even a 5 min job!)
Car looks good though, i must admit!
pony
Mon May 12, 2014 9:20 am
Quaser wrote:Lots of work going on there - going BMW main dealer only would have cost you much more then you could have got the same parts for, but you probably know that already.
All of the work was outsourced.
The first garage I used I have not used them in a few years now as their quotes are expensive and they lack the detailed knowledge of E30s. The plus point is they are very close to me. The owner is a nice enough guy he probably ain't too pleased I went to someone else. I used him a few times for my old E46 323Ci Coupe (replace radiator/water pump/ MOTs). Also the E30 work as mentioned.
When he changed the belts on the E46 323Ci WITHOUT asking me first with ECP parts (rather than New Genuine BMW!!!!) I wasn't happy. Also there was squealing noises from the belts on cold start ups which maybe suggest tension is not correct.
Gert_8
Mon May 12, 2014 1:23 pm
how much was the service book, Pony? I could do with a new one - I didn't realise they were still available.
pony
Mon May 12, 2014 1:25 pm
£18 plus VAT
jimbom30cab
Tech 1 freak
Mon May 12, 2014 1:35 pm
Great thread Pony, enjoyed reading about the work you have done on the car. It looks smashing now mate
I do like those 1 piece knobs
Gert_8
Mon May 12, 2014 1:36 pm
pony wrote:£18 plus VAT
Thank you! :)
pony
Mon May 12, 2014 1:48 pm
jimbom30cab wrote:Great thread Pony, enjoyed reading about the work you have done on the car. It looks smashing now mate
Thanks very much :-)
Yes has come along away. Still a few things I am not happy with.
More like the work I have been paying others to do for me.
I want to learn how to do a few things myself which would save a bit of money and cars are interesting anyway. I just don't feel mechanically competent to ideally would like someone to show me the ropes or watch/learn from them. Have possibly been thinking of doing an evening course about car maintenance but maybe I can learn from some mechanics instead :-)
The gear shift mechanism the previous owner Andrew Dale changed to Z3 mechanism. This is SUPER TIGHT now with some of the mechanical work done with PacerPete. I think I would have preferred it slightly looser. Also the layshaft rattle in the gearbox which was listed in the BMW Approved Used Car Check has been sorted. I beginning to wonder what a nice tight original E30 shift would feel like instead of what I currently have.
The illuminated gear knob is fitted but the illumination isn't plugged in yet and will be done soon at some point when some more mechanical work is done.
jimbom30cab
Tech 1 freak
Mon May 12, 2014 1:50 pm
hey Pony, you know what, I fitted a Z3 shifter with new bushes in the cab turd and it was too switchy for my liking. I prefer the normal throw with a new metal knuckle and rubber bush personally.
pony
Mon May 12, 2014 1:54 pm
jimbom30cab wrote:hey Pony, you know what, I fitted a Z3 shifter with new bushes in the cab turd and it was too switchy for my liking. I prefer the normal throw with a new metal knuckle and rubber bush personally.
I need to drive a as new E30 gear shift mechanism so I know what an original one feels like to see whether I prefer that.
This Z3 type one is super tight. Maybe will get a bit looser soon.
The E46 M3 CS has a nice good tight shift @35800 mileage.
However, is not as tight as the mechanism in the 325i.
pony
BMW E30 To do list
Remove steering wheel and gear knob
Bodyshop (tidy up wheel arch where someone banged wheels with me in December 2010)
Sound system
Alcantra driving gloves
Throttle cable - stiff throttle pedal
Handbrake warning light sensor - handbrake warning light does not illuminate when handbrake is ON
Fuel gauge tighten
Coolant gauge tighten
Electric fan - install
Check brakes properly are ok and why are so spongy ?
Plug in illuminated gear knob
OBC get working properly
Anything else ?
Change washer fluid and check wipers ?
Mon May 12, 2014 2:05 pm
Why do you want a electric fan?
pony
Mon May 12, 2014 3:06 pm
Blitz wrote:Why do you want a electric fan?
For DWYB
pony
Tue May 13, 2014 7:58 am
Update
This is what it currently looks like
I do enjoy driving it and is a pleasant drive. Has the outstanding issues mentioned.
Gert_8
Tue May 13, 2014 8:01 am
That's very nice.
Is that your boyfriend's telephone number? :)
pony
Tue May 13, 2014 8:20 am
Gert_8 wrote:That's very nice.
Yes you can have it you gay lord :mad:
M3888
Tue May 13, 2014 9:20 am
love the evo wheel how much was that and where did u get it ? :D :cool:
pony
Tue May 13, 2014 10:18 am
M3888 wrote:love the evo wheel how much was that and where did u get it ? :D :cool:
BMW Park Lane Battersea
Yes very £££
M3888
Tue May 13, 2014 10:33 am
ouch£££
E30M3EVO
Tue May 13, 2014 2:24 pm
Looking gorgeous..!
The car mats need changing to OEM mats.
pony
Tue May 13, 2014 2:33 pm
I have some replica floor mats from "MotorMec" which I have are brand new :-)
Thanks very much for the comments :-)
lyricalnut02
Tue May 13, 2014 4:08 pm
looking good pony :cool:
325i Sport Tech 1 - R.I.P
E30 addict.
_Jay_
Tue May 13, 2014 4:49 pm
Is this based around wood Green. Sure I have seen this about. Lovely car you have!
pony
Tue May 13, 2014 5:15 pm
_Jay_ wrote:Is this based around wood Green. Sure I have seen this about. Lovely car you have!
No not Wood Green. The steering wheel has only had a week and a half of use and already showing wear marks!!!!
