Another Turd that i had to rescue
oomz1975
Post Fri Dec 27, 2013 3:24 pm
Nice work...
l16ydl
Post Tue Jan 21, 2014 11:19 pm
oomz1975 wrote:Nice work...
Got the car back last week and was waiting to get a full day free so i could spend time getting it back together. I got it in to the unit so i could start working on it:
I had both sides painted with the front & rear valances and the bonnet all done as well. The body shop done an amazing job and you cant tell that the work had been done
I started to put the front together first:
Everything was all sorted but i just need to connect the pipes for the headlight washers.
I got the wipers put on with the seal for the bonnet, didnt get the after picture but it was simple enough.
Fitted the filler flap:
Started to do work on the inner wheel arches, gave them a lick of stone chip:
Can any one tell me where the 3 tubes connect at the top of the fuel filler neck?
With all the work done i didnt want the spare wheel spoiling anything so gave it a clean:
I pushed the car out and thought i would take some pics:
As i was running out of time, i wanted to get the centre console in and get the windows working:
Didnt get as much as i wanted to but its starting to come along so another and hopefully itll be ready for an MOT.
jimbom30cab
Tech 1 freak
Post Tue Jan 21, 2014 11:21 pm
looking brill, top work fella
G-Bear
Post Tue Jan 21, 2014 11:30 pm
Looking good
l16ydl wrote:Image
There's a lot of blue roll in the background there...
l16ydl
Post Tue Jan 21, 2014 11:45 pm
Lol, yeah a fair bit!!!
Sanchez
Post Tue Jan 21, 2014 11:51 pm
Top work, another one saved.
l16ydl
Post Sat May 31, 2014 12:37 am
Sanchez wrote:Top work, another one saved.
Over the past few months things have been really all over the place and this project has taken a lot longer to finish than expected. He is how i left her before:
I started to put the car back together, so first the came the electric aerial. I bought a new one as the i thought i lost all the parts to it but ironically found them when i was sorting through all the parts:
And then started to piece the car back together?
I had to order a load of new inserts for the trim:
The lock had failed on the drivers door, so i got a repair kit sorted:
And i got on a roll:
When i was putting the driver's rear arch liner in i knew i missing something and worked out what it was:
And then started on the sills:
As i had access to the ramp later on in the day, got on with servicing the car with a water pump and cambelt change:
Since then i have got the body work finished, mot'd and sorted out speedo as it was not registering any speed. I worked out that something had burnt out on the circuit board so i tried another and that didnt work. Worked out that the second set was faulty too so ended using a third set which worked a treat. I got working on the old adhesive from the last bonnet insulation which was a mess to get off but got there in the end:
Need to polish the car, wet vac the interior and sort a few things out and its ready to put on the market.
TheMeathead
Post Wed Jun 04, 2014 1:09 am
great job on the car buddy, reminds me of mine with the rear arches. i had to do exactly the same thing.
quick question what did you use to get the glue from the insulation off of the bonnet?
Gert_8
Post Wed Jun 04, 2014 9:35 am
iirc I think Barry mentioned the best thing for that is brake fluid...Toyota's - No, I'm not joking.
BenHar
Post Wed Jun 04, 2014 12:28 pm
Brake cleaner, not fluid!
Brake fluid will strip the paint.
Ben
Post Wed Jun 04, 2014 12:54 pm
Yes brake cleaner not fluid!!! :eek:
Toyota one works well but any solvent based brake cleaner will do.
aimlessrock
Post Wed Jun 04, 2014 1:24 pm
nice work matey, im just up the road from pm if i can help with any bits you may need (have a shed full).
E30 320i Convertible (1989)
190 Mercedes (1988)
G-Bear
Post Wed Jun 04, 2014 2:39 pm
Gert_8 wrote:iirc I think Barry mentioned the best thing for that is brake fluid...Toyota's - No, I'm not joking.
Don't worry Gert I couldn't remember if it was fluid or cleaner too that Barry had discovered. I just sat on the fence with this one... :o
_Jay_
Post Wed Jun 04, 2014 4:22 pm
Lovely example you have here!
l16ydl
Post Sat Jun 07, 2014 10:32 pm
Thanks guys, i used something called desolve which i got from my bodyshop. A good scraper is the key .
jimbom30cab
Tech 1 freak
Post Sat Jun 07, 2014 10:36 pm
Cracking work there, a real inspiration.
Great thread also, proper old school zone resto thread, one of the best
nice job
