first problem! doh! (picture of nackered sump!)
dubownerbilco
Post Tue Oct 11, 2011 9:40 pm
the offending article:
the reason why!
VW-will
Post Tue Oct 11, 2011 10:45 pm
My cars lower than 60mm, with small tyres... Havnt had a issue in a year now, stanched ftw
Finto_316
Post Wed Oct 12, 2011 9:27 pm
Finto_316 wrote:busted my 316i sump a couple months ago :x only lowered 40-50mm :D caught it on a electric gate spike :x got it welded and that sorted it :)
ermmmm i spoke to soon:(
[img][img]http://i978.photobucket.com/albums/ae26 ... photo1.jpg[/img]
a tiny little hole:( put some metal bonder on it and it has bonded an no leak now :)[/img]
BMW e30 325i Sport-88-Diamond Shwartz
JdmFanBoy
Post Thu Oct 13, 2011 9:38 pm
This shit happens man, I don't run a sumpguard because theres no room for one. Just gotta be super careful and observant. Plus every sump you smash gives you 10 scene points :D
lee
Post Fri Oct 14, 2011 10:32 am
lift the engine... mine was lower than this.. use thick washers to lift the engine. i had some under both the mounting arm and the rubber mount. must of gained 15mm.
doing this made the cross member the first thing that hit rather than the sump... i have a m10 sump with 10mm ally plate welded on the bottom if you want it for a small fee....
