Just make sure you inspect it properly for rust before comiting to spend monay on it.
Check inside the roof skin by putting the sun roof in the tilt postion and look into the roof where the sun roof panel slides into. Remove the rear seat and all the boot trim to inspect the inner rear arches. Removing the glove box helps with inspection of the bulkhead.
The picture doesn't look promising as the dreading tin worm can usually be alot worse than the minor surface rust that is visible.
Good luck with it all.
I think I have found one to save
bodger
Don't listen to the haters Barry, mine looked just like that when i found it in my mates barn, i did all the work on it myself on my drive whilst i was banned for 12 months, i think it turned out OK and at least then you will know the car inside out and can be proud that you did all the work yourself
E30Gheko
I'm with you on that totally. Mine cost me more than you have paid but in reality it does need a fair bit spending on it too. It has a lot of good parts which is how I justify shelling out more money in the first place. I also plan to do all the work I can myself. It will keep me out of the pub and it's just something I like to spend time on when I have it.Don't listen to the haters Barry, mine looked just like that when i found it in my mates barn, i did all the work on it myself on my drive whilst i was banned for 12 months, i think it turned out OK and at least then you will know the car inside out and can be proud that you did all the work yourself
It'll never be worth what I spend on it but projects give me a buzz, and I'm planning on keeping it!!
barryj
It gets better, I went round today and the guy decided to give it to me for nothing.
fuzzy
you cant say fairer than that.
You could probably break it and get back £500-1000barryj wrote:It gets better, I went round today and the guy decided to give it to me for nothing.
barryj
I am going to have a very good look at the common rust areas over the next few days as a quick poke revealed that its pretty solid, if not it will be broken.bss325i wrote:You could probably break it and get back £500-1000barryj wrote:It gets better, I went round today and the guy decided to give it to me for nothing.
