My new 316!
Junglistjed
How do i remove the left speaker panel? do i need to remove the bonnet lever?
Junglistjed
My speakers are also too deep for the hole, i personally don't have the equipment to make MDF rings.. is there a company that makes them?
anyways i removed the drivers side panel and speaker and i have placed some new wiring
Junglistjed
Great looking chromie.
mark_gpz
Yes it would be worth it! Ive got twin 45's on mine with a straight through + fart cannon is loud so keep atleat 1 silencer on lolJunglistjed wrote:Would it be worth replacing the carb with the webar? or doing a whole engine swap?
Junglistjed
panels removed and the speakers ready to go in, just waiting for the mdf rings! any idea why my heating has stopped working? no air is coming out..
Could be stuck thermostat; take it out and dunk it in a Pyrex jug of boiling water to see if it opens. If not, fit a new one.
Junglistjed
sorry to be a numpty mate, where's the thermostat at? heaters do let out some hot air but you cant regulate it, it will be the same whether its on 1 or 5..
Usually at the front of the cylinder head, underneath a dome shaped alloy housing.
You may have some difficulty getting it off though, due to corrosion...
toby
That sounds interesting - do have a thread with pics?mark_gpz wrote:Ive got twin 45's on mine with a straight through + fart cannon is loud so keep atleat 1 silencer on lol
Automaton
Did you replace all the hoses? Can you tell me where I can get a set to replace the old ones on my car?
Maneesh
1986 E30 M10 316 Manual Schwarz Chromie
1982 E28 M20 520i Henna Rot - Project
1988 E32 M70 750iL Schwarz - MASSIVE Project
1991 W201 190e Automatic Schwarz - Sold
1991 W201 190e Automatic Silver AMG Tribute - Sold
1993 E36 M40 316i Manual Brillantrot (RIP: rotting in peace)
Join other Carb Fanatics: E30 316 Carb - The Faithfuls https://www.facebook.com/groups/444263742439145/
Junglistjed
I Haven't mate! i know a store on ebay sells a lot of original e30 parts!
Junglistjed
Junglistjed
Are there any double exhausts that will be a straight fit?
Automaton
What is the name of the ebay store?
Most of them have just one hose, if at all.
Maneesh
Junglistjed
Car has started cutting out again (sigh) , heres a link to the thread i made about it > http://www.e30zone.net/modules.php?name ... c&t=245160
if anyone has any idea of whats causing it, let me know!
Junglistjed
If the engine is violently shaking about on its mounts, then yes, there is the possibility it may shake some tubes (or other parts) loose.
Junglistjed
Its weird, whenever i was driving it it seemed fine, but when i pushed on the brakes and slowed down you started to see the engine rattle
Junglistjed
Im about to purchase a weber carb, what do i need to get it fitted? has the manifold and rubber mount and im buying the choke cable, anything else?
Makes sure you have the right linkages to suit your throttle and choke cables, or buy/make appropriate adaptors - or replace the cables, as required, of course.
Good idea to fit a new gasket between carb and manifold too, unless the existing one is in good condition.
Possibly the accelerator pump diaphragm, or associated parts.
Junglistjed
A weber carb has been purchased so ill get the garage to fit that, also want it to sit lower so what coilovers will fit this car and at what sort of price?
Junglistjed
The lights for the speedo etc have stopped working.. same with one of the front lights which doesn't go to the brightest.. what could be causing this?
Have you tried rotating the headlamp switch, which also acts as the instrument backlighting dimmer?
Junglistjed
Yes i have mate :/ its the whole right side of the car.. front right light will only turn to half beam, rear brake right light doesn't turn on and speedo lights don't light up :S
Junglistjed
just checked all of the fuses and they seem fine..
Sounds like you need to check all the earths to the affected lights, and clean any corroded terminals if required.
But, check the bulbs first - it may be something as simple as a blown filament.
Junglistjed
Does half beam and full beam now use the same bulb? where is the earth to the interior speedo lights? thats the biggest of my worries as its getting dark quicker now and id like an idea of what speed im doing! haha
No, on the E30, dipped beam is on the outer pair of lamps, and main beam is on the inner pair.
Remove the insruments cluster, and undo each backlight bulb in turn and either hold it up to the light to see if the filament is broken or use a multimeter or power supply to test it.
Junglistjed
would i need upgraded shocks if i wanted to fit 60mm springs?
Yes, probably - the standard shocks are only suitable for as low as -40mm.
In any case, lowering beyond 35-40mm is ill-advised, as you'll encounter rapid tyre wear, odd handling and smashed sumps, etc.; the Sports were only lowered by -15mm.
