Hartge H27 resto
Wed Jan 06, 2010 11:16 pm
tomson wrote:I didnt know that..... but I do have a rear strut brace that looks identical to the one pictured above. It has no markings but was removed from an S50 converted E30 that Griffin did, I'm thinking it might be a Hartge one winkeye
A Griffin built S50 E30?!
Tell me more!
tomson
Wed Jan 06, 2010 11:21 pm
Tell me more!
It's the 3litre S50'd 2 door in Calypso Red (IIRC) I've seen it at Gaydon before. The guy who paid Griffin to convert his car lives in Bristol and I relieved him of his remaining E30 morsels after he sold the car a while back :D
tomson
Wed Jan 06, 2010 11:22 pm
I think it had some 17" Hartge splitties last time I saw it actually ? ?
Wed Jan 06, 2010 11:31 pm
Tell me more!
I know the car you're talking about. I didn't realise it was built b Griffin. I have the totalbmw mag that was featured in, might have another read.
Kedge
Thu Jan 07, 2010 6:47 pm
Japandrew73 wrote:Just to help and give you proof, here is the Hartge Brochure with the rear strut brace you have.
Looks the same as a rear strut brace i have, just thought it was a cheap after market jobbie. Surely the Hartge item will have some markings on it?
Instagram - Kedge85
Scott72
Thu Jan 07, 2010 8:41 pm
I have this rear bar mounted to my H23 and can't find any Hartge markings. Is kinda odd.
1984 E30 Hartge H23
1980 E21 Alpina C1 2.3
tomson
Thu Jan 07, 2010 8:51 pm
The front Hartge ones have no markings either, just a stick on badge...
Sun Mar 13, 2011 12:41 pm
Scott72 wrote:I have this rear bar mounted to my H23 and can't find any Hartge markings. Is kinda odd.
they don't have any markings at all,
is this any closer to tarmac yet ? :D
Simon
Sun Mar 13, 2011 2:46 pm
e30topless wrote: is this any closer to tarmac yet ? :D
About 100 yards! :o
Sun Mar 13, 2011 3:02 pm
pm sent Simon. :D
Finto_316
Sun Mar 13, 2011 7:11 pm
coming along nicely simon :cool:
BMW e30 325i Sport-88-Diamond Shwartz
H35-24
Thu Jun 23, 2011 10:53 pm
I'll give you some places to look for rust: You probably know typical facelift rust problem around the rear towing hook, then there's behind ALL wheels, sealer might look nice, but there can be trouble underneath. And then there's is the sunroof problem. As you probably guessed by now I've been in your position.
Now I didn't remove the carpet until after metalwork and paint. It all looks great under it, I was changing cable harnesses, I found that were they all meet in the footwell of the passengerside and go up into the IP basically were the cables come out of the slot in the inside sill and bend 90 deg they cross a big bead of sealer on the sill. I had spotted some rust there, thought it was surface rust. But it was much worse. Inside the sill the drainpipe from the sunroof comes down and lets the water out into the sill right there, so here the inside sill was rusted through inside out. This applies both sides, basically look at the inside sill under the speakers and remember to lift the wireharnesses up and look under them too. If that big sealerbead looks at all loose, bumpy or has cracks there is potiential trouble.
I have learned 3 things from my restauration work (it's my first project):
1. Don't remove the doors by unscrewing the 4 nuts that hold the hinges onto the door, that will be a pain to get right, I'm almost there after several months now, still have to do some fine tuning on the driversside, my car being a 4 door. I even managed to snap one of the studs in the passenger door, so had to drill a hole in the remains and make thread in it so a M5 bolt could be used. Instead part the hinge by removing the 1 bolt that holds it together, it so easy, but Haynes says remove the 4 nuts, idiots! I'm going to throw my Haynes manual in the fire soon, it's worthless when you have some knowledge of how a E30 are to fix.
2. Find a seriously skilled and trustworthy bodyshop to do the bodywork, if you can't do it yourself.
3. ALLWAYS remove the carpet when doing a resto project. There can be nasty things under there, and changing wireharnesses with the carpet in is a nightmare.
Why is there not enough time to do it right, but allways enough time to fix the errors - I borrowed that, just so reallistic in my line of work.
Thu Jun 23, 2011 11:29 pm
or always inspect the bodywork EVERYWHERE before you start a resto. No point throwing money mint mechanics if the body is f8cked.
Kedge
Sun Sep 30, 2012 9:15 pm
Any progress on this Simon?
Instagram - Kedge85
Simon
Sun Sep 30, 2012 10:09 pm
Nope, though I came very close to losing the engine and shell though 8O
It was stored at my place of work which went into administration just over a year ago. Was very lucky to get an opportunity to get back in before the administrators got there to remove what I needed.
It's safe back with me now parked in my garage, things are looking up at the moment so with a bit of luck can start making some progress.
I have managed to find an original boot badge after spotting a nice E36 328i Sport with it fitted for sale on Pistonheads, big thanks to the owner for agreeing to remove it and sell it to me :D
Kedge
Wed Oct 03, 2012 10:02 pm
That's a scare you could've done without, can't you reclaim something though if it belongs to you and bailifs take it to cover someone elses debt?
Instagram - Kedge85
Simon
Thu Oct 04, 2012 7:35 pm
Probably could, but it would have been a hassle I could have done without, and I doubt very much they would have taken them, probably just scrapped them, it's just a load of old scrap to them...
Just glad it didn't get that far, and I was able to get everything I needed out of there! Only thing I didn't manage to get was the front legs which isn't a problem anyway, I'd already removed the struts and springs!
Simon
Mon May 24, 2021 11:11 pm
Simon wrote:
Tue Oct 16, 2007 7:43 pm
I have driven it, only for a short distance as it hasn't been taxed and tested for about 2 years!
Nearly 17 years now...🤣
steve_k
Tue May 25, 2021 9:03 am
thread revival? would love to see any updates on this.
flybynite
Tue May 25, 2021 9:19 am
Don't worry mine was last taxed and tested in '97 24 years and counting............... 8O
Simon
Tue May 25, 2021 11:03 am
Glad I'm not the only one :mad:
steve_k
Tue May 25, 2021 12:15 pm
makes the 8yr's mine's been off the road look laughable.
Tue May 25, 2021 4:58 pm
I`m embarrassed at only eight months :o: :o:
Simon
Thu Jun 12, 2025 2:41 pm
A quick update after reading through the entire thread.
Ive not mentioned how the ECU has griffin motorsport stickers on it.
After again chatting to Kevin Bird we do think this car was built by griffin.
A house move recently means the car and all the bits are still in storage, no garage at my current place, but planning permission has been passed for a build.
Simon
Fri Dec 26, 2025 7:12 pm
So my garage is finally built, and the car is finally back home with me. Threw the lights wheels and bumpers on for some inspiration!
Managed to track down some previous keepers, including the second owner who had some very fond memories of the car.
Also spoke to the keeper that last had it on the road, who explained the missing rocker and front strut brace. He kept them as momentos! Annoyingly, when I finally tracked him down, he'd only recently sold them after holding onto them for many years!
Sat Dec 27, 2025 4:00 pm
That must have been frustrating! Did he at least have photos of them, so you could possibly get similar or replica items?
flybynite
Sat Dec 27, 2025 7:56 pm
You think that is bad, it is a lot worse if you took the now rare and expensive bits off yourself because they stopped working or you didn't like them and misplaced them over the 35 years you have owned the car. :?
Mine was built by TWR as an Alpina C1 and sold through Park Lane the year before it all went to Sytner. It had only one owner outside the family and I was lucky enough to track him down as he lived fairly local and was able to fill in some blanks.
For a few reasons many of the bits were taken off, but I still have the rare typ 136 spoiler bent in an L shape when my car was vandalised in the early 90s.
At least it is now on the historic list when I do get it back on the road :thumb:
Simon
Sat Dec 27, 2025 8:32 pm
Got a rocker cover as explained previously in this thread somewhere :o
Strut braces to come up for sale now and again. Mega bucks now though
Sat Dec 27, 2025 8:42 pm
Surely, some enterprising Chinese outfit probably produce something similar? :wink:
Simon
Sun Dec 28, 2025 8:56 pm
Id rather have the genuine article
flybynite
Mon Dec 29, 2025 9:55 pm
I'm sure you will find the parts come up for sale somewhere eventually, I don't have much left to find but I have found eBay.de to be quite helpful although not as easy as it used to be for obvious reasons.
