Saving a chromie
Post Tue Aug 04, 2015 7:13 pm
Now you can leave 11's and not 1's :D
P_VIDDY
Post Tue Aug 04, 2015 7:16 pm
I have left a few "testing the diff" 11s haha
Post Tue Aug 04, 2015 7:20 pm
It's the rules :cool:
rix313
Post Sun Aug 09, 2015 9:16 am
Car looks stunning :thumb:
P_VIDDY
Post Thu Aug 13, 2015 1:28 pm
Small update:
Fitted some decent springs H&R 35mm springs. Next step on the suspension is Bilstein B8 shocks all round then new bushes and arms front to rear. :cool:
In other news I have had my valuation come through from my insurance and the car is value at/insured for £8,000. Not bad for saying I paid £661 not all that long ago haha
Post Thu Aug 13, 2015 4:28 pm
Well done,, looks brilliant. :cool:
povertyspec
Post Fri Aug 14, 2015 11:19 am
i really like it on bottletops. its nice and period sitting. im starting to think of fitting a set to my 1.8. just got back from Thailand and saw a bautiful red unmolested E36 2.5 coupe on the 16 inch 5 lug bottles they had at launch and it looked sooooo right.
spook
League two here we come !!!
Post Fri Aug 14, 2015 7:44 pm
Tip bloody top mate , one of the nicest cars I've seen on here for a long time
Post Fri Aug 14, 2015 10:21 pm
Much better :thumb: :burn:
P_VIDDY
Post Mon Sep 28, 2015 8:09 pm
Took the old turd down to Santa pod BMW show yesterday. Managed to get my target of 14.5 seconds down the strip. So the benchmark has now been set for future mods.
Got a couple of videos...
Racing a twin turbo 335i
Onboard footage racing my mates E36 M3 track slag (one of my slower runs)
Getting ready to race :D
Other than changing all the tyres for some new continentals I have not touched the car for a while. Will be keeping using the car down to a min now winter is quickly upon us and trying to get some bits sorted. Have a few minor issues to sort and started sourcing parts for to fit air con.
Next years plan...
Sort suspension (bilstein shocks, new bushes and ball joints throughout)
Full custom stainless exhaust (made by a quality fabricator, not cheap powerflow crap)
Brakes
Future plans (hopefully next year):
More power (3.0 stroker? US m3 cams?)
6 speed conversion
Post Mon Sep 28, 2015 9:05 pm
Looking good Paul, shifts well !
:cool: :cool:
P_VIDDY
Post Tue Dec 08, 2015 8:46 pm
I have finally made a start on a full suspension overhaul.
Rear axle removed
I have every bush to replace with powerflex. New bilstein b8 shocks.
Also rear arms will be getting reinforced. Camber/toe plates welded on then beam/arms will be getting painted.
grants50
Post Fri Dec 11, 2015 6:10 pm
Very nice mate 8)
Can you take pics when you weld camber/toe plates on and the reinforced arms.
Something I want to do.
P_VIDDY
Post Sat Dec 12, 2015 9:12 am
grants50 wrote:Very nice mate 8)
No problem :D
Mr-Lachs
Post Sun Dec 20, 2015 2:09 pm
Gorgeous chromie !!! :-)
Mr-Lachs
1988 BMW E30 325iSE Auto, 4 Door, Lachs Silver (Fair Weather Machine)
2012 Vauxhall Insignia 1.8 Exclusiv, Technical Grey, (The Daily)
P_VIDDY
Post Mon Jan 18, 2016 6:48 pm
Bushes removed...
Axle bushes removed using fire
Trailing arm bushes removed using my favourite tool 8)
E30 rear arms are pretty weak and prone to bending so decided to reinforce them whilst removed
Got some of Dan's (danthe) camber plate to weld on Wednesday night then it's off for paint with the arms.
Gert_8
Post Mon Jan 18, 2016 9:31 pm
Now, that is how you replace an arch!
Superb looking car :cool:
P_VIDDY
Post Sat Feb 06, 2016 9:50 am
camber plates (supplied by DANTHE) now welded on and elongated the holes.
all ready to be 2K painted now...
I have also had to rectify a couple of issues:
due to my short shift setup (z4m) there is next to no clearance between the prop so under aggressive shifting it catches. I didn't want to change the selector as it feels great... nice and tight but not too notchy. Also I found that the shifter was not sitting central. so I modified the linkage...
I had also failed to notice the f*@ked inner input shaft bearing on the diff when i built it.... DOH!
So had to rebuild the diff again and replace the bearing
brian_s
Post Sat Feb 06, 2016 11:33 am
Looking well this is 8)
richb93
Post Wed Mar 09, 2016 9:48 pm
A true labour of love Paul! I've just finished reading the entire thread and have to say it's remarkable how much time and effort you have put into this car. It goes without saying that she is now a real beauty, one of the cleanest I have seen! Huge respect!
Very impressed!
richb93
Post Wed Mar 09, 2016 10:27 pm
Very impressed!
P_VIDDY
Post Sat Mar 12, 2016 8:53 am
Thanks guys. Rich... I shall be looking forward to updates in the future of your newly acquired 318is.
More slow progress.
Whilst the rear axle is out I have protected areas I previously coudlnt get to:
everything is now painted and almost ready to bolt back together with all new powerflex bushes and new brackets etc.
now we are starting to get nicer days I am getting the urge to drive it so time to get stuck in. Planning to be back on the road next Saturday.
jimbom30cab
Tech 1 freak
Post Sat Mar 12, 2016 9:37 am
Nice work Paul, that 2k finish looks great.
Mr-Lachs
Post Sat Mar 12, 2016 4:23 pm
Really great progress, well done :-)
Mr-Lachs
Mr-Lachs
Post Sat Mar 12, 2016 11:42 pm
Cars looking fantastic!! :-)
Mr-Lachs
P_VIDDY
Post Sun Mar 20, 2016 6:36 pm
PROGRESS!!
She is back on the road!
Rear end rebuild done...
Powerflex: trailing arm bushes. Axle bushes. Top mounts. Anti roll bar D bush and both link bushes.
Danthe's camber /toe plates welded on.
Arms reinforced
All 2k painted
New brackets, Spring pads etc
New brake pipes
Bilstein b8 shocks with h&r 35mm springs
The obligatory wash and road test
The modified selector linkage is perfect. No longer catches prop and sits perfectly central instead of looking like its in third when it's in neutral.
Car drove well considering the geometry needs sorting as i did it by eye. It's sitting higher at the rear but hopefully that will settle.
Skinhead
Post Sun Mar 20, 2016 8:24 pm
Looking good home slice
gaszman
Post Sun Mar 20, 2016 8:35 pm
At this rate i will own the only 325i sport using the original engine so many coversions
P_VIDDY
Post Thu Apr 21, 2016 9:27 am
Some snaps from last Sunday's drive 8)
P_VIDDY
Post Wed Apr 27, 2016 8:27 pm
Had my interior cleaned...
Full blog/write up here...
http://www.atd-detailing.co.uk/bmw-e30-sleeper/
MouseRat
Post Sun May 22, 2016 7:17 pm
Nice stuff! What did you use to restore the black plastic in one of the early posts? Looks like it came out decent.
And also what stuff did you use to protect the underside? I'm taking the rear end out from under my 318iS soon so I'll get to it while I can!
"The most E30-ist of E30s"
P_VIDDY
Post Sun May 22, 2016 7:53 pm
Thanks.
For the plastics I used fine wet and dry and then rattle can spray painted with satin black. Looks OE but fresh. Still look perfect over a year later. I just just trim shine now.
As for the underbody I used a shutz gun
Kedge
Post Sun May 22, 2016 8:20 pm
Great looking motor this is Paul, proper stealth!
Instagram - Kedge85
P_VIDDY
Post Sun May 22, 2016 8:31 pm
Cheers Dave. As with most builds the only limit is time and/or money 8O
andysheep
Post Sun May 22, 2016 10:08 pm
Great thread,very nice welding,im thinking i could improve a bit more,keep it up :D
