No where dips in Ireland nor does anywhere use plastic media so Soda blasting is the best I can make of the situation.Kos wrote:No, shell should be dipped to see the full extent of the damage, then repaired and then be taken back to coated
At the moment:polsta wrote:whats the exact process your thinking ?
are you dipping it after ? then the various other coatings, its major work to do a car like this and more so with the rust issues you have and will find, you cant leave it hanging around in bare metal state for long once its blasted, then it sounds wierd to blast, prime, then start welding, unless its going back to be dipped ? , to really do a proper job the shell needs to be 100% finished and solid then to be dipped and treated and coated as a finished shell, its a big big job for a professional with a lot of expirience and a phenominal amount of cash, personly id go buy an m3 with the money it will all cost
Mounted on the rotisserie and soda blasted & sand blasted (for sealant etc) Primed to prevent rust
Body work (cutty cutty)
Blasted again
Paint.
Ideally it needs dipped but I'm not hauling the shell back and forth to England. The body work and paint job is being done at mates rates so it's not working out tooooo badly for my wallet.
