Ok Been doing a little bit with the engine lately.
I had to go out and buy another 325i inlet manifold as the one I purchased more then a year ago from a zoner has not yet arrived
Anyway moving on.
This thing was filthy when I got it and it looked like it had been floating around in the gulf of mexico. Oil was dripping out of it everywhere.
The 325i inlet manifold
Look at the difference between the 325i manifold and the other manifold.
Throttle body mount...... 325i on the bottom or the big hole.
Inlet ports...... Yep the 325i one is the big one on the left.
Now we move onto port matching the head to the manifold, Here I have got a thin piece of sheet aluminium 0.5mm that I have drilled a few holes into to locate with the head studs. I have then got a ball pein hammer and rolled it into the ports to make something like a cast of the ports.
Now I have to cut out the little egg cups I have created.
Now I place it back on the head to make sure its correct.
It all matched up as exactly as it should except the mangled one where the die grinder decided to buck back and attack me.. So we transfer it to the inlet manifold.
Well what do you know, it seams the ports on the 325i inlet manifold are a exact match to the ports on the 731 head... Strange this is as I thought I would definitely have to open the ports in the head to match the port on the manifold...
This is a bit weird because the LARGER 885 head is being restricted by the 325i inlet manifold so it begs the question what is the point in the 885 head if its strangled for air?
Either way this is good news for me as now I dont have to port match everything together as BMW already did it for me..
Now that that is out of the way I can move onto assembling the head.
Time to slide in the rocker shafts and mount the rockers.
The cam seal.. Pretty important to get this bit right as if its a little out or the seal gets damaged then there will be a oil leek.. That would really suck as it would be a ass to fix.
Head is all together now looking sweet. Its a bit fiddly but a few hours later.
Thats it for this weeks update
Mike
