Air box DIY
JF008
Thu Aug 07, 2014 10:01 pm
I have been wanting an air box ever since my m50 swap, the pod filter was sitting in the middle of the engine bay sucking up all that heat as well as looking ridiculous. Not to mention the annoyingly loud induction noise!!Image
I did not want to experiment with oem options so I looked for other alternatives. I found those 3 web pages most interesting for ideas:
http://www.r3vlimited.com/board/showthread.php?t=185577
http://ls1tech.com/forums/16096461-post162.html
http://members.dodo.com.au/~wawawa/e30index.htm
Things I used: Offset tin snips, 2mm aluminium sheet, 2mm edge grip seal, a steel ruler, divider with two metal points and a pair of vice grips.
So here's what I have done, first I've printed this pattern taken from the 3rd link above, after editing it to the right size. (each square represent 1cmX1cm)
Then gathered my stuff
I traced the pattern on cardboard, adjusted that a few times then traced it to my aluminium sheet. I made two brackets incorporated to the box, both facing inward on the radiator side, one visible here at the top and the other one on the opposite lower corner. Both using existing holes.
With the lid:
I polished it using 1200, 2000, 3000 grit sand paper and Mother's mag and aluminum polish.
Before/after shot:
Inside painted black for maximum stealth... also drilled holes at equal spacing.
Its very easy to make and I'm well pleased with it. The car is now much more enjoyable to drive as the bassy reverberating resonance in the cabin is now totally gone! Man that induction noise was loud! The box is very solid too.
Top tip: Making a deep scratch using a carpet knife or similar, against a straight edge, will make bending the aluminium very easy at that spot.
Ok, have a nice day now :thumb:
JF
Edit:
I could not keep the box clean and it looked bad with water marks etc so I had it powder coated black with a grainy texture. Looks better and easy to clean :D I also put the plastic thingy back behind the headlights to avoid sucking water in!
G-Bear
Thu Aug 07, 2014 11:08 pm
Nice work there
M3smudge
Fri Aug 08, 2014 8:16 am
Great work.
russ325i
Fri Aug 08, 2014 9:17 am
That looks bang on, good work!
h2ggv
Fri Aug 08, 2014 9:22 am
Could read threads like this all day top work :D
bigbird76
Fri Aug 08, 2014 8:13 pm
Looks a nice neat job and nice to see peeps taking pride in the workmanship.
Leigh
oomz1975
Sun Aug 10, 2014 7:38 pm
Nice work.
P_VIDDY
Sun Aug 10, 2014 7:59 pm
Top job
initial_g
E30 Zone Moderator
E30 Zone Moderator
Sun Aug 10, 2014 9:01 pm
Top work love it!
JF008
Sun Aug 10, 2014 9:18 pm
Thanks for the kind words 8)
