the car origionally had a 2.7 aplina c2 engine in it but this was replaced for a high compression e30 325i engine
so this is how she was before she left for mine
be more pictures tommorow when i get along to the garage and get everything cleaned out
the car has its light grills in the boot but most of the interior is basically stripped so its most likely going to stay that way
also the car is to get booked into a shot blasters to get took right back to bare metal so i can get a full bare metal respray in diamond swartz black
theyres going to be a massive list of stuff to be done and with the plans thats been rushing through my head id be happy to see it on the road by 2010 if that
the thing people may like the car is having a cage harnesses buckets and the stripped looked purely because i dont want the car to have the concours look interior but i do on the exterior i know it sounds majorly daft but makes sense in my head
so the big list of plans
chassis - wheels - tyres - brakes
kw variant 3 coilovers
power flex bushes all round
25mm antil roll bar front
19mm antiroll bar back
custom made font strut tower (strut to strut then bolts back to buck head)
custom made rear strut tower (strut to strut then diagonal bar to the floor )
kazz 2 way lsd
m3 front wishbones
solid engine mounts
hi - spec 4 pot capliers
285mm grooved and drilled discs
ferrodo ds500 pads
good ridge steel braided lines
16 x 8 , 16 x 8.5 bbs lm (reps i know)
205 / 45 /16 goodyear eagle f1's all round
Exterior
M-tech 1 bodykit
Bmw bonnet roundel smoothed
will be a fair bit of exterior smoothing to be done but just thinking what would look best first
Interior
Dash flocked
oil temp , oil pressure, water temp , boost , volt meter gauge all built into the glovebox
Carbon fibre sheets Replaced as door cards
Bucket seats or some description looking at recaro spg's at the moment
willans 4 point harnesses
Engine
2.5 6 cylinder engine
Forged pistons and rods (still researching this)
supercharged or turbo'd still looking at pro's and con's
so its going to be a long and expensive build but when ya know the right folk your ok
remember the only thing thats confirmed at the moment is the shotblasters so everything will hopefully be done in time
