Rear lowerering suspension alignment
Turbo-Brown
Boost Junkie
Post Thu Jun 02, 2005 2:23 pm
HELP!
What do I do?!
How do I get rid of the negative camber? Is it something I can get the stealer to sort out?
Cheers!
astondg
Post Thu Jun 02, 2005 2:39 pm
A little bit of camber is ok, how much have you lowered it? I think anything up to about 3cm lower would be ok. I don't know about factory parts but I got some K-Mac adjustable trailing arm bushes for mine. They just replace the standard trailing arm bushes but adjust for camber and toe.
Aston
BMW E30 323i with some stuff
1:21.67 @ Morgan Park Raceway
Boots_Walker
Post Thu Jun 02, 2005 2:40 pm
you can get eccentric trailing arm bushings from BMW, but i dont think they are very effective (does anyone know how much camber correction you can get from the offset bushings?). there are adjustable aftermarket bushings available too but i have heard they dont hold their adjustment very well
there are other options but they can be a bit more involved (modifying subframe etc)
Turbo-Brown
Boost Junkie
Post Thu Jun 02, 2005 5:16 pm
Supposedly it's having a 40mm drop (got the bilstein sport line kit I think)
Will give it a go I guess.
Any more info on the adjustable bushes?
Jos
Post Thu Jun 02, 2005 10:24 pm
http://e30m3performance.com/tech_articl ... c_bush.htm
Fairly good info on the K-Mac ones, I assume any eccentric bush would be similar though.
'94 e36 tree climber
