got a shock today!!!!!
AndyBird
Post Wed Jun 01, 2005 9:25 pm
new leads for the 318 Ԛ£80ish :eek:
anyone know what gapping the sparkplugs should be to save me Ԛ£20 ?
F reg 318i M40 i beleive
Post Wed Jun 01, 2005 9:32 pm
plugs should already be gapped... well bmw ones are anyway
android
Post Wed Jun 01, 2005 9:35 pm
I don't know, but until someone gives the right answer, try 0.030"(0.75mm) That should be enough to get you going.
Gwynleym10
Post Wed Jun 01, 2005 9:40 pm
Ԛ£80? is that from the dealer?
Try www.eurocarparts.co.uk they are Ԛ£50+vat+delivery(unless you pick them up..)
Plugs are Ԛ£1.45 each...already gapped, but tis .8mm
u sure u need HT leads? they "arcing" in the dark?
Have you looked for vacuum leaks as well, the air intak bellow (after AFM) often cracks.
Found out where your plugs go yet?
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
AndyBird
Post Wed Jun 01, 2005 9:56 pm
cant suss out where that plug goes yet
the main air leak was the intake pipe wasnt connected properly to the afm/airbox
ive put it all back together after cleaning it all and now it idles way too high like 2k revs cold and 1-1.5k revs warm :mad:
still got the miss abit on idle and low revs but doesnt miss on high idle (2k revs)
cant see any arching on leads the rotor and leads llook new but tryin got elimate everything
would incorrectly gapped plugs cause a miss on idle and not up the rev range?
AndyBird
Post Thu Jun 02, 2005 8:44 am
bttt gonna be working on this tonight as supposed to be drifting saturday, got my diff welded but need to sort this idle and misfire problem :x
Colin
Post Thu Jun 02, 2005 10:24 am
Never trust the gap on new plugs. Who's to say that some monkey didnÔš't drop it at the packing plant? The plug is the heart of the engine so taking a second or two to check it right is defiantly worth it. The gap size will be shown on the box and if you are in doubt I would buy new one's. I think NGK are as good as they get. Good luck.
Gwynleym10
Post Thu Jun 02, 2005 10:56 am
ive put it all back together after cleaning it all and now it idles way too high like 2k revs cold and 1-1.5k revs warm Mad
This sounds like the idle control valve or ICV, if you can locate it give it a good clean with brake/carb cleaner.
As for thte missing, make sure the end up th HT leads and the plugs are clean and snuggly fitted.
London 2 Cape Town
