Anyone explain what the degree numbers on a cam mean?
PeteE30Tourer
Just because i like to understand these things, can anyone explain what is meant by the numbers quoted for uprated cams, e.g. 272/284. I gather one is for the inlet and one for the outlet valves, but what does it really mean? How does this affect engine performance as the numbers change, i.e. what's the difference between a 272/284 and a 284/284?
Borderbmw
Basically the numbers mean the duration of the inlet/exhaust lobes when the cam rotates a full 360 deg,so it stays open for say 270 deg of a 360deg rotation etc,hope this helps mate?
Jos
The longer the duration is the more fuel/air mix can enter the engine, the more fuel/air there is the more power is produced. Same for the exhaust side, the longer it is open the more waste gas is expelled from the cylinder.
Reasonable explaination here:
http://www.streetracersonline.com/articles/camshafts/
'94 e36 tree climber
PeteE30Tourer
Excellent - thanks again Jos - very interesting reading.
