Help fitting M-Tec 2 spoiler please
Has anyone out there figured out how to fit the M-Tec 2 spolier to a car that hasnt previously had a spoiler? obviously i need to figure out where to drill my holes but how on earth do i do that? Come on, some bright spark must have worked this out.. Thanks in advance all
josh-hocking
- Teenager with Taste !
yeah yu need a template as maxfield says
ian332isport
- Contact:
There's no template for the rear spoiler. You need to use a tape measure.
Thanks guys!ian332isport wrote:There's no template for the rear spoiler. You need to use a tape measure.
Ian, have you managed to drill the required holes using your measurements? if your method is tried and tested its an invaluable bit of info!
ian332isport
- Contact:
My car came with one fitted as standard, so it's not something I've had to try. Those measurements are from an official BMW installation procedure though.BillyWiz wrote:Ian, have you managed to drill the required holes using your measurements? if your method is tried and tested its an invaluable bit of info!
Cheers,
Ian.
Thanks very much Ian, i'll give it a shot once i get my kit back from the spray shop. Fingers crossed!ian332isport wrote:My car came with one fitted as standard, so it's not something I've had to try. Those measurements are from an official BMW installation procedure though.BillyWiz wrote:Ian, have you managed to drill the required holes using your measurements? if your method is tried and tested its an invaluable bit of info!
Cheers,
Ian.
