Tyre Pressures?
Musashi
Tue Apr 01, 2008 10:48 pm
Just wondering what the tyre pressure would be for a 325i cabby sitting on 205/45/16's? I am currently doing about 32 all around? is that right?
StefanAnghel
Wed Apr 02, 2008 6:52 pm
the same Q but 316i with 205/40/17...30psi all around????
thanks
GrooveRyder79
Wed Apr 02, 2008 8:01 pm
I read somewhere 30f 33r, sounds about right for a rear wheel drive car.
Dave_M3
Wed Apr 02, 2008 8:41 pm
Yep, that sounds about right. All depends on the way you drive too of course and the tyres your using. But for normal lesuirely driving around .1-.3 bar more in the back is about right for an E30.
Anybody know what they find best with 215/40 R17s?
insertnamehere
Thu Apr 03, 2008 5:05 pm
The way I drive, if I run at the recommended tyre pressures for their size (found in the back of the owners handbook) the sidewalls get as much wear as the tread!!!
1977 Austin Allegro 1300
1992 FIAT Tipo 1600 (SOLD!!! 8O)
1977 MZ TS250/1 "supa-5"
1993 Cagiva Mito 125
1987 E30 318i (Daily driver for????)
1988 E30 325i (Not anymore, let down by seller...)
