how do you adjust the height of power steering pump
Fraz06
Tue Apr 01, 2008 10:19 am
Hey guys, how do you adjust the height of the power steering pump on the m20 engine to go up or down? in order to replace the power steering belt
thanks guys
fraser
Tue Apr 01, 2008 12:58 pm
Similar arrangement to that provided for alternator adjustment, but it's best accessed from underneath.
Fraz06
Tue Apr 01, 2008 1:17 pm
thanx for the reply, what's the arrangement for alternator adjustment? if it is the same as the power steering pump adjustment, just so i know how to adjust the power steering pump as im a novice and this is my first time changing the power steering belt.
Thanks guys
Regards
Fraser
bodger
Tue Apr 01, 2008 1:24 pm
there is an adjusting bar with teeth on it , loosen the nut which clamps the pump to this and it will adjust, then to tension the belt turn the adjuster nut to corrct tension then tighten clamping nut again, sounds harder than it is
