what is this
chief
Post Mon May 30, 2005 6:33 pm
any body know what this tool does
i have no idea must be simple i'm sure
ian332isport
Post Mon May 30, 2005 6:45 pm
It's used to help align the wheel bolts when you change the wheel.
You put the grey plastic end in one of the wheel bolt holes in the hub, and then slide the wheel over the shaft. Once the wheel is sitting on the hub, you can put the bolts in without having to jiggle it around to get them lined up. When three are in, you just pull the shaft out and put the last one in.
Those Germans think of everything :mad:
Ian.
Widge
Post Mon May 30, 2005 6:55 pm
It also slides in to the sparkplug tube spanner to give leverage. The germans only make somthing if it can do 2 jobs at once :wink:
chief
Post Mon May 30, 2005 7:00 pm
thank you very much for your time guys
seems like it has more than one use
want to sell it on e-bay along with lots of other bits of mine but couldn't list it without knowing what it is obviously
Post Mon May 30, 2005 8:47 pm
And the second job for the spark plug spanner, is to undo the electric sunroof drive nut. ( see appropriate thread).
Widge
Post Mon May 30, 2005 8:48 pm
And the steering wheel nut when you don't have the right socket!
:roll:
chief
Post Mon May 30, 2005 9:19 pm
love that picture on the bottom of your posts
Widge
Post Mon May 30, 2005 10:27 pm
Wot mine?
chief
Post Mon May 30, 2005 10:37 pm
yes yours widge
love those exploded graphic views
