What material do I need for the job - I'm guessing sheet mild steel? Any particular grade?
What thickness should the metal be around the footwell area? I would like this to remain as a jacking point if poss, is there anything I should be aware of? Thicker metal needed etc?
The driver's side footwell hole is quite near the accelerator pedal - should the mount for this be removed and reattached or is this unnecessary unless it's actually on the rust?
Recommendations on future rust prevention? Primer, paint, and underseal??
Any advice, tips, tricks very much appreciated
