hi
a couple of things really
what is the correct voltage for a battery when the car is ideling is 13.64 to low? i was always under the impression it should be 14 or above
what would cause a new battery (which has gone flat and been charged up 3 or more times) to drain itself when not attached to anything say from 12.07 to 12.02 in an hour?
any help would be appreciated
cheers
Electrical help please!!
no fitted a new battery months ago
left it off the road for a while so the battery was compleatly dead jumped it moved it jumped it moved it etc but never enough to let the battery charge.
went out for 15 miles today came back took the battery out and is dropping as above?
1988 M3 lachs silver S50B32
1989 325i sport delphin grey
1993 316i lux touring lazur blue
- Brianmoooore
Modern batteries don't take kindly to being fully discharged.
Have you checked for excessive battery drain when the car is switched off?
