rear suspension help
snoops
Major Helmet
Sun Mar 02, 2008 12:43 pm
Im in the process of changing the rear springs/shocks on my car, I've removed the shock and lowered the trailing arm but I can't get the spring out
any help/tips will be much appreciated
fuzzy
He who sleeps with "Gingers"
Sun Mar 02, 2008 12:45 pm
spring compressors.
snoops
Major Helmet
Sun Mar 02, 2008 12:46 pm
i thought spring compressors were only needed for the fronts?
fuzzy
Sun Mar 02, 2008 12:48 pm
usually the standard springs are tight but lowered springs usually drop out when you take the shock off.a crowbar will do the job but keep your fingers clear
snoops
Major Helmet
Sun Mar 02, 2008 12:49 pm
:thumb:
cliffybabe
Powered by Nelly
Powered by Nelly
Sun Mar 02, 2008 1:05 pm
yeah be careful using the persuasion bar winkeye
go get some cheap compressors its alot safer
Aleksandar
Sun Mar 02, 2008 6:52 pm
It can be unsafe without a spring compressor, not worth it. You'll need it in the future anyway. :wink:
snoops
Major Helmet
Sun Mar 02, 2008 8:46 pm
done it with the crowbar in the end I will be getting spring compressors soon when I change the front suspension
abelai
Sun Mar 02, 2008 10:03 pm
I assume you had the handbrake off?? Because if you didn't that would be why you were having problems.
If I can't fix it I'll f**k it up so bad nobody can!!
snoops
Major Helmet
Sun Mar 02, 2008 10:34 pm
no handbrake was on :o:
Gwynleym10
Sun Mar 02, 2008 11:35 pm
And did you undo the Anti roll bar? Shouldn't need a crow bar, just push down on the trailing arm (stand on it!) while pushing the spring out with your other foot. Like this the spring has no load to go flying anywhere!
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
snoops
Major Helmet
Sun Mar 02, 2008 11:38 pm
it was a 316i so no rear anti roll bar, tried standing on the trailing arm but it wouldn't come out, in the end levered it out towards the centre of the car with a crowbar
abelai
Mon Mar 03, 2008 11:38 am
Well you live and learn, basically the handbrake will stop the semi trailing arm droping down and if you have an ARB just jack both sides up.
