Bodge or not?
Peter325iSE
Sat Mar 01, 2008 10:10 am
I recently noticed the overflow pipe at the top of the petrol tank was leaking.
See: http://www.e30zone.net/modules.php?name ... ic&t=94537
Rather than paying £20 for a new length of pipe from BMW, I disconnected the pipe from the tank, cut an inch off where the pipe was frayed and secured it back on with a new clip. There is quite a fair bit of slack in the pipe so it's quite comfortable, even though it's an inch shorter.
Bodge 8) or bodge :cry: ?
Peter
blitz877
AKA ajm-e30
Sat Mar 01, 2008 10:12 am
thats exactly what i did last weekend mate, but you'd be better off in the long run replacing the pipe as mine was still cracked after i cropped it a bit
**BANNED**
Sat Mar 01, 2008 10:39 am
Strangely enough,I trimmed the one on both of my cars as well.....must be a proper bodger... When I first bought the Daimler I discovered that it had a disconcerting habit of letting it's brake servo fail,usualy on the approach to the rearend of a very expensive car. Traced it to a frayed end of pipe on the manifold take of to the servo.You will have guessed by now how it was fixed....
Youth is wasted on the young.
Sat Mar 01, 2008 3:59 pm
Peter325iSE wrote:I recently noticed the overflow pipe at the top of the petrol tank was leaking.
Peter
Sounds like the best type of bodge - one that's worked and hasn't cost you anything !! :D
fuzzy
He who sleeps with "Gingers"
Sat Mar 01, 2008 4:08 pm
not a bodge just used a bit common sense.
Aleksandar
Sat Mar 01, 2008 8:15 pm
Yeh I replaced a small vacuum hose with a part of a bigger broken vacuum hose but it wasn't cracked...If it's cracked it won't last long.
