misfire
Guest
just notice 2day,under full throttle,as the revs pick up i get a misfire almost like its running on five cylinders??... it starts fine and idles ok,mayb a bit lumpy but no obvious missing,could this just b plugs??!
Plugs, rotor arm or distributor cap for a start.
Check out the rotor arm and cap as well sometime in the not to distant future.
New plugs mat have cured your misfire, but a worn cap/rotor and part worn perfectly servicable plugs can cause ignition problems which will be cured for a while by new plugs.
