Coolant
forvie
Thu Feb 21, 2008 10:54 pm
Why does my coolant light keep coming on,water level is spot on??
kam-325i
Thu Feb 21, 2008 10:55 pm
Knackered water level sensor.........common for these to go now.....
march109
Thu Feb 21, 2008 10:57 pm
sensor problem?
tezk
Sun Feb 24, 2008 5:16 pm
Try wrapping some wire around the two pins visible when you remove the connector from the sensor and re-assemble.
Effectively bypasses the sensor, but make sure it isnt low coolant levels first :wink:
Sun Feb 24, 2008 6:12 pm
tezk wrote:Try wrapping some wire around the two pins visible when you remove the connector from the sensor and re-assemble.
You'll remember that piece of wire is there one day, when your car starts to misfire and you suddenly notice the temperature gauge is hard in the red.
Sort the switch properly - it's a real engine saver!
