Torque spec for valve cover
chimp
Post Tue May 24, 2005 9:02 am
does anyone have the torque spec for the valve cover...just had mine powder coated and ready to reinstall... My car is a E30 M3 Thanks
elliot
Post Tue May 24, 2005 9:22 am
not sure that there is one tbh. need to clarify that though
Borderbmw
Post Tue May 24, 2005 9:35 am
The figure quoted is 9-11 lbs/ft but as long as you tighten it down evenly and dont use a 24" breaker bar you/it should be fine.
ian332isport
Post Tue May 24, 2005 12:56 pm
Borderbmw wrote:The figure quoted is 9-11 lbs/ft but as long as you tighten it down evenly and dont use a 24" breaker bar you/it should be fine.
I believe the official figure is only 10Nm which is a bit less than 10 lbs/ft.
It's not quite that critical on the M20 that has studs and nuts, but on the 318is which has special bolts with rubber washers, it's very important not to overtighten or the M6 thread in the head casting strips very easily.
Ian.
chimp
Post Thu Jun 02, 2005 7:51 pm
Thanks guys!!!!!
