John
The S14 motor has no sender for oil level. So if you have a 320iS and it has the original engine, then it should also have a check panel (probably in Potugeuse or Italian) that has no oil check light.bruvs1 wrote:The annoying red `motor oil' light has come on on my 320iS. The engine is sweet and the levels are too
. So i presume i have a wiring fault if there is no way of switching the damn thing off
. It came on after i had cleaned the heater fan motor out and lubricated the bearings. I've cleaned the sump connection, the 3 plugs on the bulkhead and the pins in the big loom connection on the bulkhead - still no joy........Any ideas?
John
