I have an Tourer with only a rear fog light. If i get a set of front fog lights and a new dual switch is that sufficient to get the front fogs to work?? or do i need a wiring harness.
Richard
Re: Front Fog Lights upgrade
Some E30's fitted without fogs have the dash bulb but the vast majority don't.jcjdavis1 wrote:Hi There is a sticky that will tell you how to take clocks out to put the warning bulb in the back.Very easy job.
