LSD rebuilding and parts locating
Gunni
Post Mon May 23, 2005 11:21 am
where to locate rebuild parts, how much and such?
also any rebuilding info for our lsdԚ´s?
Gunni
@ 2012 VEMS group buy !!
M3Compact
Post Mon May 23, 2005 7:42 pm
Gunni wrote:where to locate rebuild parts, how much and such?
You can use Ford Atlas (Capri) rebuild packs. They're Ԛ£120 and you get 4 plates but you only need 2. If you get your LSD casing machined you can fit all 4 plates and it makes the diff much nicer to use.
Gunni
Post Tue May 24, 2005 1:06 am
do you know how to rebuild the diff? or is it like all other LSDԚ´s
also how do I have the LSD casing machined
Gunni
Turbo-Brown
Boost Junkie
Post Tue May 24, 2005 8:27 am
Any idea where you can get the plate kits from?
I've tried searching on google but not had much luck :(
Cheers!
M3Compact
Post Tue May 24, 2005 9:50 am
It's just a standard ZF LSD unit.
The casing/end plate need machining to allow for the increased length of the cluster with the extra plates. (Approx 50 thou, and a plain washer/spacer discarded.)
Some 4 plate Atlas kits on the shelf here:
http://www.motoscope-online.co.uk/
Quaser
Post Wed May 25, 2005 11:23 am
So is it possible to convert an open diff to an lsd?
Turbo-Brown
Boost Junkie
Post Fri May 27, 2005 1:56 pm
I'm looking at a couple of options at the mo.
One is to make an LSD using the bits from an open diff having made a new carriage, other being to make something which applies pressure to the little gears inside, although that wouldn't provide much of a lock up :(
M3GTR
Post Sun May 29, 2005 9:48 am
Hi
Can you keep us (me!) informed on this conversion mate? I've got an open diff that would be ideal to re-build for the racer into an LSD as a spare.
Paul
