engine wiring info.
gall
Mon Feb 04, 2008 5:30 pm
will a engine start without the oil switch wired in? just been trying to get ric325i new 325 started but as yet haven't changed the switch to the new one(pre facelift car, facelift wiring).
cheers
Andy.
benjy
Mon Feb 04, 2008 5:49 pm
Should do.....as the switch only lights up the lamp in the dash cluster, I take it this is on an e30??
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
gall
Mon Feb 04, 2008 5:55 pm
yeah on a e30 mate, i thought the sensor tell the ecu thats there pressure before it start the engine.
maybe, but i don't know.
brian help.
andy.
Tue Feb 05, 2008 9:09 am
All the oil pressure switch does is control the light on the cluster. The ECU neither knows nor cares whether the switch is connected or not.
gall
Tue Feb 05, 2008 5:03 pm
Ok cheers brian, will have to go through the wiring again then!
cheers again.
andy
